69' hood hinge
yellercat
69' hood hinge
Post by yellercat »
Looking for a good used hood hinge for the DRIVERS SIDE for a 1969 Camper Special F-250. A set will be ok too.
Seems like they would be the same as for the F-100s but not sure.
Thanks-
1970 F100 302 C-4 factory air
JWW
Re: 69' hood hinge
Post by JWW »
Yes, hinges from 67 - 72 will work. DC has them, I'm sure other do as well (LMC, NPD, Auto Krafters). However, others may have some used ones for you as well.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
yellercat
Re: 69' hood hinge
Post by yellercat »
thanks JWW, found a used one not far away and looks to be in good shape, got my fingers crossed.
Funny, the original had a very short hairline crack at one of the inner pivots and thought that it might go ahead and work. NO GO. Too much stress, it folded like a card table!
JWW
Re: 69' hood hinge
Post by JWW »
yellercat wrote:thanks JWW, found a used one not far away and looks to be in good shape, got my fingers crossed.
You bet. The nice thing about these trucks is a lot of items interchange with each other. If you get a chance, look at this technical page with tons of information. One of those is a parts interchangeable list.
http://www.fordification.com/tech/technical-index.htm
JWW
2004 F150 Crew Cab
