67-72 F100/F250 door dome light brackets and switches with harness
sinaloagold
Post by sinaloagold »
Im trying to piece out the door dome light switch system on my 69 F250 since it didn’t come from the factory with one. I would need the harness first. If anyone is willing to part and sell. Thank you.
Re: 67-72 F100/F250 door dome light brackets and switches with harness
=sinaloagold post_id=773750 time=1645378311 user_id=122127
Highly suggest you save yourself some money and grief and replace them with dent era switches and harness(s) like i did BC #16. :wink:
The bump era door switches have always been a part that needs constant attention due to the two small pins corroding/breaking/losing conductivity. :doh:
And you'll find the wires/circuit that feed power to the the switch(s) black w blue stripe tucked just inside the cab under the dash, (which can be fabbed very easily versus getting brittle 50+ year old wiring). :2cents:
sinaloagold
The actual switch is different, so they should interchange between dents and bumps? Thank you for the input.
=sinaloagold post_id=773828 time=1646410126 user_id=122127]
Yes the dent era switch is different but they'll use the same mounting holes, (they have "blade" type terminals versus the tiny pin type our bumps came with-a much more reliable switch).
So you do have to change the two wire harness at both doors as well, (an easy task). :wink:
96 jag ranger
Post by 96 jag ranger »
I need the right and left door panels for my 72 green explorer special they are the high trim sport custom
