Cleaning up wiring - cosmetics
dotcentral
Post by dotcentral »
I'm almost done with painting my inner fenders, jack, battery box. It's been a little awkward but not too hard. Now, my wiring and connectors look a little bad by comparison. What are some good ways to clean these up without damaging anything? I was thinking about vinyl cleaner and scrub pads. Anything better? I need to use something that won't make a mess out of the new paint. Thanks.
oldschoolrods
re: Cleaning up wiring - cosmetics
Post by oldschoolrods »
get some electrical cleaner.... that way you dont F any of the connectors up.
oldschoolrods
I used that same stuff on mine i got it from tractor supply
bryantracing460
Post by bryantracing460 »
my wife used to work at a place that made wiring harnesses for boat dashes. They were throwing that stuff away by the 50 gallon drum. Talked to the guy that was hauling it off and got about 2 barrels full.
Jeremy
Faithful Old Road Dog
Post by Faithful Old Road Dog »
I used that wiring loom out of newer mopars, like the k-car style. They had the plastic "t's" that made it look a lot cleaner if you had wiring branching off the main path. I was never a believer in highlighting my wiring with the bright colors that are available. That's just me.
