Hi all,
I have a 70 250 with a manual steering box that looks like this:
Any idea what I should be putting in it for lubrication?
Thanks!
Manual Steering Box Lube
- sparky72
Re: Manual Steering Box Lube
Service manual says to fill with SAE-90 EP engine oil, believe it or not.
Taylor
Well, that's convenient. Thanks for the info!
BTW, what manual is that? Think I should probably have one
Looks like the Ford Factory manual. My set is 5 volumes.FloridaFordGuy wrote: ↑Wed Feb 01, 2023 6:24 pm Well, that's convenient. Thanks for the info!
- jzjames
Recommend you use grease with the grease gun. Fill it up full.
The 90 wt. can leak past the seals.
Awesome. Thanks!
- sparky72
Like Lee said, it's the '72 Ford shop manual. It's a reprint, not an original set. I forget where it's from but I believe you should still be able to get a hard copy from somewhere online, somewhere around $100 or so, perhaps a bit less. Or you can get digital copies for much less, but I like having the paper copies on the garage bookshelfFloridaFordGuy wrote: ↑Wed Feb 01, 2023 6:24 pm Well, that's convenient. Thanks for the info!
Taylor
