Hi all. 1970 Ford F250 camper special here.
A couple weeks ago I noticed some liquid streaming down on the interior, passenger side from right under the dash below the glove box where air duct runs for the ventilation system. I figure that there were some gaps around cables passing through the engine/firewall so I sealed up any opening that I could find in the engine bay.
Today much more fluid leaked out while driving and I noticed that it is viscous, sticky and kind of green in color....radiator fluid?? I do see what looks like a hose running from the rear of the radiator through the firewall. Any idea what would be leaking right behind/below the dashboard glove box?
Coolant (?) leak inside cab
- Gaslight
Re: Coolant (?) leak inside cab
Chances are that is a failing heater core. It could still be a hose leaking into the interior. But really its going to be a failing heater core. You will need to remove the heater system from under the dash and put in a new heater core.
Jake
Jake
1969 F100 Ranger
Here are a few threads that have good information in them about the heaters, there are also some Youtube videos that show people replacing their heater cores on these trucks. Hope this helps
http://www.fordification.com/forum/view ... hp?t=82940
viewtopic.php?f=6&t=73960&st=0&sk=t&sd=a
http://www.fordification.com/forum/view ... hp?t=44760
