Picked up a 1972 F350 Sport Custom. Has a 11 foot flatbed. 390 and c6 transmission and power steering and brakes. Factory discs up front.
When I brought it home. Used my International 175C loader and a long chain to pull it off the trailer.
https://www.instagram.com/p/Cr9AA4oplUl ... IwNjQ2YQ==
Then I pulled it in the barndominim I'm building and put new brakes on. Replaced everything except the hard lines, master cylinder and booster. At this time I also had new tires mounted. I did end up getting new brake calipers too but didn't take pictures.
https://www.instagram.com/p/Cr9BGnqJ5w0 ... IwNjQ2YQ==
Then I found these neat Holley valve covers. Also decided to replace the mirrors with ones in better shape.
https://www.instagram.com/p/Cr9BVT5pcxJ ... IwNjQ2YQ==
Then a overview of the truck. Had the valve cover off because I thought cylinders 2 and 3 had a bad head gasket. Turns out it was crossed plug wires at the distributor cap.
https://www.instagram.com/p/Cr9BdssJ0OO ... IwNjQ2YQ==
Added yet another bump
- OldRedFord
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- Gaslight
