68/69 Aux fuel tank filler hose
So I removed my aux tank to replace the rubber lines because the vent hose was cracked. Come to find out no one makes the fuel filler hose or I cannot find it. What have y’all done to get the proper length hose? I’m trying to bring back the aux tank so I can use it and not have to fill up every 15 minutes (joke). Thanks
1969 VW Beetle (Daily)
1968 F-250 (Walter)
Weber grill hoarder
ISS Protection Team
1968 F-250 (Walter)
Weber grill hoarder
ISS Protection Team
- basketcase0302
Re: 68/69 Aux fuel tank filler hose
I'm pretty sure that Keith our founding member and administrator is currently working on his aux tank too as I write this.=Vwbuggin69
Shoot over to the Fordification fakebook group and look for his post there.
I never had the aux tank but am guessing the regular gas filler hose wont' work?
Thanks for the tip. I posted on his FB post. FIngers crossed he has found a hose I could use.basketcase0302 wrote: ↑Tue May 16, 2023 7:08 amI'm pretty sure that Keith our founding member and administrator is currently working on his aux tank too as I write this.=Vwbuggin69
1968 F-250 (Walter)
Weber grill hoarder
ISS Protection Team
1968 F-250 (Walter)
Weber grill hoarder
ISS Protection Team
You might check with LMC Truck because that is where I picked up my set of hoses and "U" shaped sheetmetal shield where it crosses over the frame.
- Jbarnes79
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
When I restored my truck, a neighbor of mine worked at Dayco. I measured the size of the hose and bought one from them rated for fuel. It’s been in my truck for 32 years.
