January 1969 - December 1969
Bulletin No. 107 - January 24, 1969
(15 articles)
  • Article 1625 - Air Cleaner Body Gasket - (F-B-C-6000-7000, C-8000 Trucks with Caterpillar V-8 Diesel Engines)
  • Article 1626 - "W" Series Radiator Improvements - (All "W" Series Trucks)
  • Article 1627 - Dana Power Lok Axle Chatter Complaints - (1967-68 F-100, 250 &350, F-100 & 250 4x4; P-350, 3500, 400 and 4000 U-100 and 1969 E-300)
  • Article 1628 - 1969 Mustang Rear Shipping Tie-down Plate Removal - (1969 Mustangs with Dual Exhaust System)
  • Article 1629 - Brake Pedal Free Height Specification - (Ford, Mercury and Meteor)
  • Article 1630 - Non-Functioning Air Cleaner Duct and Valve Assembly
  • Article 1631 - Master Cylinder Replacement within the Warranty Period - (All Car Lines)
  • Article 1632 - Seat Belt Anchor Bolt - Special Tool - (All Car Lines)
  • Article 1633 - Fuel Pump Diagnosis and Repair - (All Passenger and Truck Engines)
  • Article 1634 - Improved Front and Rear Brake Assemblies - (600-1000 Series Trucks with Bendix Wedge Air Brakes)
  • Article 1635 - Accelerator Bell Crank to Intake Manifold Clearance - (1969 Mustang and Fairlane with 250 CID Engine Built Prior to November 15, 1968)
  • Article 1636 - Air Cleaner Identification and Installation - (F-B-6000-7000, C-6000-7000-8000 Series Trucks with Caterpillar V8 Diesel Engines)
  • Article 1637 - Flywheel Ring Gear Installation - (Caterpillar V8 Diesel Engines with 14" Single Plate Clutch F-AB-C-6000-7000, F-C-T-8000)
  • Article 1638 - Driveline Vibration - (1968 & '69 F-100 4x4)
  • Article 1639 - Special Cortina Bulletin - (1966-1968 Cortinas - All Models)
