January 1969 - December 1969
Bulletin No. 109 - February 14, 1969
(23 articles)
  • Article 1652 - Part Number Correction on Article #1582, bulletin #104, Dated December 13, 1968 - "Loose Quarter Panel Outside Moulding" - (1969 Ford - All So Equipped)
  • Article 1653 - Instrument Panel Lower Flange Rough Edge Above Brake Release Handle - (1969 Mustang)
  • Article 1654 - Premature Plugging of Fuel Filters - (All Car and Truck)
  • Article 1655 - Vendor Supplied Air Conditioner Kits - (All Cortina)
  • Article 1656 - Part Number Correction on Article 1611, Bulletin #105, Dated December 20, 1968 - C-6 Intermediate Servo Lever Shaft Hole Sealing - (All 1969 Vehicles with C-6 Automatic Transmission Assemblies)
  • Article 1657 - Erroneous Oil Dipstick Readings - 1969 428 Cobra Jet Engines - (All So Equipped)
  • Article 1658 - Gear Shift Control Assembly Four-Speed Transmission - (All 1969 Passenger Cars with Four-Speed Shift Linkage)
  • Article 1659 - Four-Speed Manual Transmission Output Shaft Removal - (1964/1969 Ford, Fairlane, Mustang and Falcon Vehicles)
  • Article 1660 - Correction to Bulletin No. 105, Article 1605, December 20, 1968 - Converter Cleaning / One Plug Drain - (All Vehicles with XPL, XP3 and FMX Automatic Transmission Units with Only One Converter Assembly Drain Plug)
  • Article 1661 - Improved Cobra Jet Clutch Pressure Plate - (1969/1968 Fairlane and Mustang Vehicles with Four-Speed Transmission and 428-CJ Engine)
  • Article 1662 - Tailgate Window Disengagement - (1969 Fairlane and Falcon Station Wagon - Model 71)
  • Article 1663 - Light Leaks at "PRND21" Selector Assembly - (All 1969 Thunderbirds with Fixed Steering Columns)
  • Article 1664 - Mislocated Deluxe Roof Luggage Rack Attachment Holes - (1969 Ford - Station Wagons - Model 71 - So Equipped)
  • Article 1665 - Column Mounted "PRND21" Indicator Adjustment - 1969 Ford with Automatic Transmission - (All Models So Equipped)
  • Article 1666 - 1969 Mustang "E" Features and Specifications - (1969 Mustang - Model 63D (2-Dr. Fastback))
  • Article 1667 - Seat Spring Elements Click Against Headrest Brackets - (1969 Thunderbird - All Models)
  • Article 1668 - Column Mounted Neutral Switch Substitution - (1969 Ford, Fairlane and Falcon)
  • Article 1669 - Jack Column Rattles and Becomes Dislodged - 1969 Ford Station Wagon - (All 71 Models)
  • Article 1670 - Approved Automatic Transmission and Power Steering Fluid Suppliers - (All Car Lines, Light Trucks and Econoline)
  • Article 1671 - Loose and/or Corroded battery and Starter Cable Connections - (All Vehicles 1968 and 1969)
  • Article 1672 - Cornering Lamp Circuit Protection (Fuse) - (All 1969 Thunderbirds)
  • Article 1673 - Vacuum Leaks Between Carburetor and Spacer - (All 1968 and 1968 Eight Cylinder Engines with Aluminum Spacer)
  • Article 1674 - Gap Between Rear Seat Cushion and Rear Seat Back - Leather and Vinyl Trim Only - (1969 Thunderbird - Model 65 - Without Pull-down Armrest)
