January 1969 - December 1969
Bulletin No. 128 - December 5, 1969 [COMPLETE]
(20 articles)
  • Article 2011 - Deluxe Roof Luggage Carrier Installation
    (1970 Ford - Fairlane)
  • Article 2012 - Radial Ply Tire Tread Wear Pattern
    (1970 Thunderbird Equipped with Radial Ply Tires)
  • Article 2013 - Automatic Load Leveler Tubing Hanging Below Frame
    (1968-1969-1970 Ford with Load Leveling System)
  • Article 2014 - Shift Linkage Plastic Grommets
    (All Passenger Car Transmissions)
  • Article 2015 - Three Speed Manual Transmission Floating Counter Shaft (Cluster) Design-Clearance Specifications
    (1967/1970 Fairlane, Falcon, Mustang and Maverick Models with Six Cylinder Engines and Three Speed Transmission Models - RAN-S1, T1, Y, AL, AM, AN, AW, AW1, AV, AV1, AX, AZ, BA, BA1, BB, BB1, BC and BC1)
  • Article 2016 - Four Speed Transmission - High Shifting Efforts
    (1970 Fairlane (Torino) with Four Speed Manual Transmission)
  • Article 2017 - C4 Automatic Transmission - Main Control Removal
    (All 1970 Vehicles So Equipped Except Falcon)
  • Article 2018 - C4 Automatic Transmission - Manual Valve Retaining Ring
  • Article 2019 - C4 Automatic Transmission Erratic Shifting
    (1969 Fairlane, Mustang and 1970 Mavericks with Six Cylinder Engines)
  • Article 2020 - C6 Automatic Transmission - Over-running (One-Way) Clutch Failure
    (All 1969-1967 Vehicles So Equipped Except Cobra Jet)
  • Article 2021 - Air Inlet Connector Leakage
    (All F-T-8000 Trucks with Caterpillar V-8 Diesel Engines)
  • Article 2022 - Electrical System Diagnostic Tips
    (1970 Thunderbird; all car lines)
  • Article 2023 - Horn Switch Insert Deterioration - Three Spoke Rim-Blow
    (All 1969 Passenger Cars So Equipped)
  • Article 2024 - Temperature Gauge Reads High
    (Thunderbirds with Automatic Temperature Control - 1970)
  • Article 2025 - Windshield Defroster Operation on Left Side Inadequate
    (1969 Ford)
  • Article 2026 - Hum in Radio Speakers
    (Ford with AM/FM Radio and Air Conditioning - 1969)
  • Article 2027 - Power Windows and/or Tailgate Window Inoperative
    (All 1965-70 Ford and 66-70 Fairlane)
  • Article 2028 - Loose Fiberglass Rail Attachments
    (Cars)
  • Article 2029 - R.P.O. Roof Luggage Carrier Installation
    (Ford and Fairlane - 1970 Model Station Wagons)
  • Article 2030 - Ball Joint Lubrication
    (All Car Lines - 1965-1970)
