January 1969 - December 1969
Bulletin No. 130 - December 19, 1969 [COMPLETE]
(16 articles)
  • Article 2033 - Hydraulic Brake System Bleeding - Alternate Method - (All "C" Series with Hydraulic Brakes - 1957-1970 Models)
  • Article 2034 - Air Compressor Mounting Bracket Loosening - (F-B-6000-7000 and F-T-8000 with Caterpillar Diesel Engines - 1968-69)
  • Article 2035 - Power Steering - Pump Whistle Noise - (All 1970 Passenger Vehicles and Trucks So Equipped)
  • Article 2036 - Auxiliary Transmission Low Gear Bushing Seizures - (All Tandem Trucks with Spicer Model 7041 Auxiliary Transmissions - 1963-69 Models)
  • Article 2037 - New Water Pumps to Reduce Engine Heat - (Medium, Heavy and Extra Heavy Trucks with 330, 361 and 391 CID Engines - 1969-1970 Models)
  • Article 2038 - Anti-Freeze Protection Revision - (1970 F-100-350, Bronco, Econoline and P-Series)
  • Article 2039 - Cooling System Pressure Specifications - (Bronco, Econoline and All Trucks - 1969-1970)
  • Article 2040 - Radiator Filler Cap Removal - (All 1970 Passenger Cars, Econolines, Bronco, F-100/350 and P-350/5000 Models)
  • Article 2041 - Misrouted Speedometer Cable - (Fairlane 1970)
  • Article 2042 - Noise and/or Poor FM Reception - (Vehicles Equipped with AM/FM Stereo Radio)
  • Article 2043 - Antenna Installation - (Fairlane 1970)
  • Article 2044 - Air Conditioning Thermostatic Switch Replacement - (1970 Ford with A/C)
  • Article 2045 - Door Glass Pulled From Channel - (1969 Carlines Using Bonded Door Glass [Most Hard Top Models])
  • Article 2046 - Electric Window Regulator Removal of Motor and Drive Assembly - (All Car Lines)
  • Article 2047 - Loose Grille Work on Plastic Head Lamp Covers and Grille Assemblies - (Ford - Fairlane - 1970 Models - So Equipped)
  • Article 2048 - Luggage Rack "Riv-Nut" Installation - (1970 Ford - Fairlane Station Wagon)
NOTE: This is the final TSB for 1969.
Last bumped by FORDification on Wed Apr 29, 2009 2:21 pm.
