January 1970 - December 1970
Bulletin No. 139 - May 8, 1970
(17 articles)
  • Article 2301 - Engine Compartment Noise in Passenger Compartment - (All Vehicles with Large Multiple Connector Vacuum Manifold on Dash Panel - 1969-1970)
  • Article 2302 - Sure Track Brake Sensor - Service Tool Application - (Thunderbird with Pinion Mounted Sensor - 1970)
  • Article 2303 - Disc Brakes - Lateral Runout Specification Revision - (F-250 4x2 and F-350 Model Trucks - 1969 and 1970)
  • Article 2304 - Brake Squeak Correction (THIS ARTICLE SUPERSEDES TSB NO. 136, ARTICLE 2212, DATED 3/27/70) - (Cortina with Disc Brakes)
  • Article 2305 - Lower Suspension Strut Insulator Kit - Vibration During Braking Correction - (Fairlane, Mustang, Maverick - 1970 Built Before 9/27/69)
  • Article 2306 - Power Steering Reservoir Cover Removal - L Series - (L-LT-LN-LTN-9000 with Detroit 6-71 Engines - 1970 Models)
  • Article 2307 - Steering Column - Shaft Rattle - (All Car Lines 1969-1970 except Cortina)
  • Article 2308 - Rear wheel Bearing Installation Procedure - (Trucks with Dana Full Floating Axles - F-250-350, E-300, P-350-400, P-3500-4000)
  • Article 2309 - Exhaust System Grounding - (Maverick - 1970)
  • Article 2310 - fuller Transmission Range Shift Cylinder - Inoperative - (Heavy and Extra Heavy Trucks with fuller RT-910 or RTO-913 Transmissions - 1970 and Past Models)
  • Article 2311 - Automatic Transmission Specifications - (Ford, Meteor, Fairlane, Montego, Mustang, Cougar and Maverick with 240-1V, 302-2V, or 351-2V Engines and C4 Automatic Transmissions - 1970)
  • Article 2312 - Accelerator Return Spring - Correct Installation - (1969 N-NT, 1970 W-WT & Prior Model Year Trucks Equipped with Cummins NH Series Engines)
  • Article 2313 - Carburetor - 1V - Rough Idle or Vacuum Lines - (All Units with 170 or 200 CID Engine and Carter YF-1V - 1970)
  • Article 2314 - Speedometer Cable Routing - ("L" Series with Air Brakes and Single Speed Axle - 1970)
  • Article 2315 - Transmission Shift Pattern Decals - Loss of Adhesion - (Medium, Heavy, Extra-Heavy Trucks - 1970)
  • Article 2316 - Seat Cushion Covers Wrinkled - (Fairlane 2-Door Equipped with Bench Seat - 1970)
  • Article 2317 - Front Seat Cushion Tears at Seat Back Latch Area - (Fairlane - All 2-Doors with Bench Seat - 1970)
