January 1970 - December 1970
Bulletin No. 142 - June 5, 1970
(17 articles)
  • Article 2340 - Changes to Wheel Alignment and Balance Programmed Instruction Book - (All Cars)
  • Article 2341 - Front wheel Grease Retainer Installation - (All Passenger Cars Except Cortina - 1970)
  • Article 2342 - Steering Gear - Improved Sealing at Input Shaft - (Econoline - 1969-70)
  • Article 2343 - Shift Lever noise - Standard Transmissions - (Falcon, Fairlane & Maverick With Column Mounted Gearshift Levers - 1969-1970)
  • Article 2344 - Bronze Walking Beam Bushing lubrication for Increased Durability - (L Series - 1970)
  • Article 2345 - Low Oil Pressure Indication During Steep Grade Operation - (Bronco with 302 CID Engine - 1970)
  • Article 2346 - Hard Starting Engines Equipped with Transistorized Ignition - (All F & B 600 thru 750 Series Trucks - 1967-1970)
  • Article 2347 - Courtesy Lamp Switches - Identifying Proper Service Replacement - (Ford, Thunderbird - 1970)
  • Article 2348 - Sensor Coupling Service - DistoVac and/or Speed Control - (Ford, Thunderbird - 1970)
  • Article 2349 - Speedometer Driven Gear Tight Fit - (Ford and Thunderbird with Speed Control - 1970)
  • Article 2350 - Key Warning Buzzer Inoperative or Intermittent - (All Car Lines Built Prior to March 15, 1970 with a Key Warning Buzzer)
  • Article 2351 - Intermittent Wiper Governor Replacement - (Fairlane with Intermittent Wipers - 1970)
  • Article 2352 - Noisy Windshield Wiper Operation and/or High Park Position of Wiper Blades - Fairlane - 1970)
  • Article 2353 - Air and/or Water Leaks - W-Series - (W Series Steel and Aluminum Cabs - 1966½-1970 Models)
  • Article 2354 - Power Window Motor Application - SUPERSEDES TSB ARTICLE 2202 DUE TO INCORRECT PART NO. LISTING - (Thunderbird - 1967-70)
  • Article 2355 - Power Window Switch Bezel Loose - (Ford - 1969-70)
  • Article 2356 - Sun Roof Panel - (All Thunderbirds Equipped with Sun Roof)
