January 1970 - December 1970
(34 articles)
- Article 2357 - Vacuum Brake Boosters Service Kits Updated - (All Medium, Heavy and Extra Heavy Trucks - Vacuum Assisted Hydraulic Brakes - 1968-1970 Models)
- Article 2358 - Brakes - Air in System Following Servicing - (All Passenger Cars with Disc Brakes)
- Article 2359 - Front Axle Identification - 12,000# "Steerease" and "Conventional" - (L-LT-LTS-LN-LNT 800-900-8000 and 9000 Series Trucks - 1970)
- Article 2360 - Front End Noise Due to Shock Absorber Mounting Bracket and Radius Arm Contact - (Econolines - 1969-70)
- Article 2361 - Driveline Coupling Shaft Support Bracket - ("L" Series Trucks with Two Piece Driveshaft - 1970)
- Article 2362 - Driveline Rumble Noise - (Ford - 1970)
- Article 2363 - Transmission Noise All Gears - New Process 4-Speed - (F-100/350 F-Series Truck - 1970)
- Article 2364 - Automatic Transmission - New FMX Front Clutch Sun Gear - (Vehicles with FMX Transmission - 1970)
- Article 2365 - Automatic Transmission - Delayed Minimum Throttle Shifts and/or 3-4 Shifts - (Units with Automatic Transmission and DistoVac - 1970)
- Article 2366 - Transmission Oil Temperature Gauge Operation and Test - (All Heavy and Extra Heavy Trucks with Transmatic Transmissions - 1970)
- Article 2367 - Lack of power or "Flat Spot" - (Trucks Equipped with 391 CID Engines - 1969 [California] and 1970)
- Article 2368 - Oil Economy - LPG 316 CID Engine - (Medium and Heavy Trucks with Production Installed LPG Conversion - 1970 Models Only)
- Article 2369 - Engine Valvetrain Squeak - (429 CJ/SCJ - 1970)
- Article 2370 - Engine Rear Support to Engine Attaching Bolt Loosening - (F-T-8000 Trucks with Cat V-8 Diesel Engines - 1968-1969)
- Article 2371 - Engine to Radiator Aspirator Hose Rubs on Air Cleaner Flange - "L" Series - (Cummins NTC and NHCT Diesel Engines - 1970 "L" Series)
- Article 2372 - Air Compressor Discharge Line Rubs Engine Injector Lines - (Heavy and Extra Heavy Trucks ["L" Series] with Caterpillar Diesel Engines and Air Brakes - 1970 Models)
- Article 2373 - Crankshaft Damper and Pulley Loosening - (Trucks Equipped with 6-71 Detroit Diesel Engines, Without Power Steering - 1969 and Prior Models)
- Article 2374 - Air and Fuel System Nylon Tubing Specifications - (Model 600-900 Series Trucks with a Gas or Diesel Engine - 1970)
- Article 2375 - Body Lift Cylinder Hose to Air Cleaner Inlet Tube Interference - ("W" Series Trucks - 1969)
- Article 2376 - Air Cleaner Servicing with Power Take-Off Hood and Extended Front Bumper - ("L" Series Trucks - 1970)
- Article 2377 - Air Inlet Hose Restriction - "L" Series Trucks - (Detroit Diesel 6-71 Engines, L-LT-LN-LNT-9000 Trucks - 1970)
- Article 2378 - Vertical Exhaust Pipe Upper Bracket Loose at Cab - (All Models So Equipped - 1970 "L" Series Trucks)
- Article 2379 - Upper Radiator Hose Sagging - "L" Series - (L-LN-LNT-LT-LTS-9000 Series Trucks Equipped with Cummins Diesel Engines - 1970)
- Article 2380 - New Water Pumps to Reduce Engine Heat on 330, 361, 391 C.I.D. Engines - THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 2037, BULLETIN 130 - (Medium, Heavy and Extra Heavy Trucks with 330, 361 and 391 C.I.D. Engines - 1969-1970 Models)
- Article 2381 - Speedometer Cable - Housing Damage Due to Raising Vehicle with Frame Contact Car Lift - (All Vehicles)
- Article 2382 - Neutral Switch - Hunt or No Start in Park - (All Models with Steering Column Mounted Neutral Switch and Fixed Steering Column, 1968-70)
- Article 2383 - Ignition Key Inconsistently Operates Ignition Lock - (All 1970 Car Lines)
- Article 2384 - Ignition Lock Key - Difficult Entry - (All Cars with Steering Column Ignition Lock - 1970)
- Article 2385 - Radio Static - "L" Series - ("L" Series Truck with Radio & G.P.D. 65 or 85 Amp. Alternator - 1970)
- Article 2386 - Air Conditioning - Intermittent Operation - (Ford 1969-1970)
- Article 2387 - Air Conditioning Not Cooling Cab Satisfactorily - "L" Series - ("L" Series Trucks - All Models Equipped with Air Conditioning - 1970)
- Article 2388 - R.P.O. Bostrum Seat Scuff Plate - "L" Series Cab - (All "L" Series So Equipped)
- Article 2389 - Tailgate Power Window Inoperative - (Ford - 1970)
- Article 2390 - "L" Series R.P.O. Butterfly Hood Latch - (All "L" Series So Equipped)
