January 1970 - December 1970
Bulletin No. 144 - July 3, 1970
(16 articles)
  • Article 2931 - Vibration/Shake Problems - Tires and Wheels - (All Car Lines - 1969-1970)
  • Article 2932 - Tire Rotation - (All Car Lines Equipped with Belted Bias Ply Tires - 1970-1971)
  • Article 2933 - Brakes - Uneven Braking - (Maverick - 1970)
  • Article 2934 - Power Steering Gear - Ford XR-50 - Torque - Specifications - (All Cars and Trucks So Equipped)
  • Article 2935 - Rear Suspension Bottoming - (Maverick - 1970)
  • Article 2936 - New Driveshaft Assembly Lubrication Instructions - (Bronco - All Models)
  • Article 2937 - Automatic Transmission - Proper Manual Linkage Adjustment - (All with Automatic Transmission)
  • Article 2938 - Automatic Transmission - Erratic Shifts - (Maverick, Mustang, Falcon & Fairlane with Six Cylinder and Automatic - 1970)
  • Article 2939 - Automatic Transmission - C6 Delayed or Erratic Shifts - (All with C6 - 1969-1970)
  • Article 2940 - Carburetor - 4300 4V - Brake Stop Stall - (All with 4300 4V Carburetor - Early 1970)
  • Article 2941 - Light Bulb Burn-Out Caused by Use of Booster Battery - (All Vehicles)
  • Article 2942 - Tail Lamp Wires Too Long - ("L" Series Truck - All Models - 1970)
  • Article 2943 - Air Conditioning - Intermittent Operation - SUPERSEDES TSB ARTICLE 2386 - (Ford - 1969-1970)
  • Article 2944 - Front Seat Back Angle - SUPERSEDES ARTICLE NO. 2332, DATED MAY 22, 1970 - (Fairlane, Models 54-57-71 [4-Dr.] - 1970)
  • Article 2945 - Front End Sheet Metal Reinforcements - (School Bus Models B500-B750 - 1967-70)
  • Article 2946 - Rearview Mirror Looseness - (Carlines with Button Type Windshield Mounted Rearview Mirror - 1970)
WEBMASTER'S NOTE: The following note was printed in TSB #147:
PLEASE NOTE: Due to a printer's error, all articles published starting with TSB No. 144 were mis-numbered. This error was a transposition of the digits 2391 to 2931. Thus, the block of numbers 2391 to 2930 were not assigned.
