January 1970 - December 1970
Bulletin No. 148 - September 4, 1970
(28 articles)
  • Article 3024 - Power Steering Fluid Cooler Leaks - (Ford - 1970)
  • Article 3025 - Steering Column Squeaks - (E100-300 Econolines - 1969-1970)
  • Article 3026 - Improved Reyco 101 Spring - (Trucks Equipped with Reyco 101 Suspension - 1969-70)
  • Article 3027 - 1971 Pinto Shift Pattern - (Pinto Vehicles Equipped with Four-Speed Manual Transmissions - 1971)
  • Article 3028 - Automatic Transmission C-4 Spline Wipe Out - Forward planet Carrier - (All with C-4 - 1967-1970)
  • Article 3029 - Automatic Transmission - C4 - Drawn out 1-2 Shifts/3-2 Downshift Cutloose - (All with 200 CID and C4 Automatic Transmission - 1970)
  • Article 3030 - Automatic Transmission - FMX - Front Clutch Failures - (All with FMX - 1968-1970)
  • Article 3031 - Automatic Transmission - FMX - New Front Clutch Piston Outer Seal - (All with FMX Transmission - 1968-69)
  • Article 3032 - Fuel Tank - Clogged Rear Vent Tube - (Fairlanes Without Evaporative Emission System - 1970)
  • Article 3033 - Distributor Breaker Cover Incorrect Positioning - (Ford 302 & 351W Engines - 1971)
  • Article 3034 - Fuel Starvation - Impproved Fuel Tank Selector Valve [Gasoline] - L-Series - (LN 500-750 & L-LN-LT-LNT 800-900 Trucks - 1970)
  • Article 3035 - Carburetor - Hesitation or Stumble on Acceleration and/or Severe Cornering - (Ford - 428 P.I. - 1970)
  • Article 3036 - Increased Clearance - Lower Radiator Hose to Frame - L-Series - (L-Series Trucks with 8V-71 Detroit Diesel Engines)
  • Article 3037 - Trailer Light Connection - (All Car Lines - 1970-71)
  • Article 3038 - Stop Lamp Switch Inoperative - (F- and B-500 through 750 with Mechanical Brakes - 1969-70)
  • Article 3039 - Turn Signal Switch - Installation Precaution - (All Car Lines with Tilt Column - 1970-1971)
  • Article 3040 - Instrument Panel Lights and/or Cigar Lighter Inoperative - (Thunderbird without Console - 1970)
  • Article 3041 - Warning Buzzer - Parts Interchangeability - (Thunderbird - All Equipped with D0SB-13150-C2 Warning Buzzer - 1970)
  • Article 3042 - Instrument Cluster Gauges - High Pointer Indication and/or Cluster Lights Inoperative - (Econoline - 1970)
  • Article 3043 - Windshield Wipers - Unsatisfactory Wipe Pattern - L.H. Side - L-Series - ("L" Series Truck - All Models - 1970)
  • Article 3044 - Windshield Fogging After Operation of Air Conditioning Unit - (All Vehicles Equipped with Manual Air Conditioning System - 1969-71)
  • Article 3045 - Power Window Motor Removal - ADDITION TO TSB ARTICLE 2976 - (All Car Lines - 1971)
  • Article 3046 - Tail Lights or Power Tailgate Window Inoperative - (Ford Station Wagon - 1970)
  • Article 3047 - Thunderbird Convertible Upper Back Panel Limit Switch - part Substitution - (Thunderbird Convertible - 1964-1966)
  • Article 3048 - Seat Belt Assemblies - Installation of 1971 Parts into 1970 Vehicles - (Ford - All Models except 76 - 1970)
  • Article 3049 - Radiator Grille Ornament - Loose or Missing - (Maverick - All Models - 1970)
  • Article 3050 - Back panel, Engine Side Panel and Transmission Cover Panel Weld Separations - W-Series - ("W" Series Highway Tractor - All Non-Sleeper Aluminum Cabs - 1969-1970)
  • Article 3051 - Door Rattles, Cracks and Loose or Inoperative Glass - W-Series - ("W" Series Highway Tractor with Aluminum Cabs - 1967-70)
