January 1970 - December 1970
Bulletin No. 156 - December 18, 1970
(28 articles)
  • Article 3216 - Catalog Supplement No. 3 - Special Service Tool Price List
  • Article 3217 - Trailer Towing Equipment Recommendations - (Ford, Torino, Thunderbird, Mustang, Maverick - 1970 and 1971)
  • Article 3218 - Battery Ground Cable - Proper Positioning - (Pinto with 2.0 Liter Engine - 1971)
  • Article 3219 - Tip-In-Moan Correction - (All with 8-Cylinder Engines)
  • Article 3220 - New Front Brake Lining - (All Medium and Heavy Trucks with 15 x 3 Inch Hydraulic Front Brakes and 6000 or 7000 Pound Capacity Front Axles - 1970 and Prior Models)
  • Article 3221 - Steering Gear Assembly Change - (Pinto - 1971)
  • Article 3222 - Traction-Lok Differential Case Redesign - (All with 8", 8¾ or 9" Locking Axle - 1971)
  • Article 3223 - Standard Transmission Service - (Pinto - 1971)
  • Article 3224 - Automatic Transmission - Binding Main Oil Pressure Boost Valve - (All with C4 or C6 - 1967 through 1971)
  • Article 3225 - C4 Automatic Transmission - Light Throttle Torque Demand Shifts - (All wit 302-2V or 351W-2V - 1970 and 1971)
  • Article 3226 - Training Handbook Correction - (C-6 Automatic Transmission, Course 7521, Vol. 71 S4 L2)
  • Article 3227 - FMX Automatic - Soft or Slipping Upshifts with Light to Medium Throttle - (All with 351-2V - 1970)
  • Article 3228 - Speedometer Driven Gear Change - (Ford Police, Taxi and Rental Units with 2.75:1 Axle and G78x15 Tires - 1971)
  • Article 3229 - Oil Leak - Oil Level Indicator - Engine - (Pinto - 2000cc Engine - 1971)
  • Article 3230 - Overheating Engine - SUPERSEDES TSB 153, ARTICLE 3151, DATED 11/20/70 - (351-C/400-C Engines - 1970-71)
  • Article 3231 - Cylinder Liner Protrusion Specification Change - (P-3500/5000 Models - 242 & D.S.O. 363 C.I.D. Dorset Diesel Engines - 1967-70)
  • Article 3232 - Cylinder Head Bolt Torque Specification - (P-3500/5000 Models - 242 & D.S.O. 363 C.I.D. Dorset Diesel Engines - 1967-70)
  • Article 3233 - Fuel Restriction or Starvation Due to Fuel Tank Contamination - (All Passenger Cars - 1971)
  • Article 3234 - High Fuel Consumption - Leaking Power Valve - Light Truck - (F100/250 with 360 or 390 CID Engine)
  • Article 3235 - Fan Component Identification - ("W" Series Trucks with 8V-71 Detroit Diesel Engines - 1971)
  • Article 3236 - Oil Filter Removal - Econoline with 302 CID - (Econoline w/302 Engine & Power Steering)
  • Article 3237 - Cigar Lighter & Horn Inoperative - Fuse Blown - THIS ARTICLE SUPERSEDES ARTICLE 3154-C TSB 153 - (Mustang - 1971)
  • Article 3238 - Marker Lamp Switch - Improved - ("L" Series Trucks - All Models - 1970-71)
  • Article 3239 - Air Vent Control Binding and/or Noisy - (Mustang/Pinto with Standard Heater System - 1971)
  • Article 3240 - Front Seat Back - Rattle - (Ford - Models 53-57-71 with RPO Split Bench Seats - 1969-70-71)
  • Article 3241 - Fiberglass Fractures at Fender Sight Rods - L Series - SUPERSEDES TSB 140, ARTICLE 2335 - ("L" Series Trucks - All N-NT-F-FT Series - 1970)
  • Article 3242 - Pinto Folding Rear Seat Steady Rest - (Pinto Cars wit Folding Rear Seatback - 1971)
  • Article 3243 - Instrument Panel Pad and Upper Finish Panel - Loose Retention - (Ford - All Models - 1971)
WEBMASTER'S NOTE: This is the final TSB for 1970
