January 1970 - December 1970
(29 articles)
- Article 2049 - Master Cylinder to Spring Tower Interference - (1970 Fairlane with Power Brakes)
- Article 2050 - Disc Brake Noise Correction - (1969 and 1970 All Carlines)
- Article 2051 - Brake Booster Noise or Vehicle Vibration Upon Brake Application (1970 Ford Station Wagon and Police Units Built Prior to 12/15/69)
- Article 2052 - Parking Brake Equalizer Rattle or Buzz - (1970 Fairlane)
- Article 2053 - Rear Suspension - Rattling or Knocking Noise at Rear Leaf Springs - (1970 Fairlane/Torino Station Wagon and Ranchero)
- Article 2054 - Steering Gear Contamination - (1966-1969 "W" Series)
- Article 2055 - Power Steering Pump Fluid Aeration and Noise - (All 1965 through Present Cars and Trucks with Ford Design Power Steering Pumps)
- Article 2056 - Locking Steering Column Running Change - (1970 Maverick)
- Article 2057 - Cast Iron Front Spring Shackles for Improved Durability - (1966-1969 "W" Series Trucks)
- Article 2058 - New Front Spring Pin for Improved Durability - (1966-1969 "W" Series Trucks)
- Article 2059 - Clutch Housing Attaching Bolt Seal Oil Leakage - (1970 Fairlane and 1969 Ford Vehicles with 429 CID Engine and Standard Transmissions)
- Article 2060 - Difficult Shifting - (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 1791, BULLETIN 115) - (Econoline - 1969-1970)
- Article 2061 - Automatic Transmission Specifications - (All 1970 Vehicles Equipped with a C4 Automatic or C4S Semi-Automatic Transmission)
- Article 2062 - C6 Automatic Transmission - 3-2 Timing Valve Deletion - (All 1970 Vehicles Equipped with C6 Automatic Transmission Assemblies)
- Article 2063 - Excessive Floor Pan Heat Correction - (1969 Ford with 390-2V and 429-4V Engines)
- Article 2064 - Lower Radiator Hose to Radiator Support Interference - (All F-T-8000 Trucks Equipped with Caterpillar V-8 Diesel Engines)
- Article 2065 - Larger Coolant Temperature Sending Unit Hole in Cylinder Head - (1970 242 CID Dorset Diesel Engine)
- Article 2066 - Starter - Slow Crank After Hot Soak - 351W - (THIS ARTICLE SUPERSEDES ARTICLE 1777, TSB #114) - (Mustang, Fairlane, Ford - 1969)
- Article 2067 - Alternator and Regulator Servicing Tips - (All Vehicles Equipped with Alternator)
- Article 2068 - Speed Control Has Slow Response to "Set" and "Accelerate" Switch - (Thunderbird - 1970, Ford - 1969 & 1970)
- Article 2069 - Engine Warning Lights Inoperative or Malfunction - (Ford and Falcon - 1970)
- Article 2070 - Stop Lamps Inoperative - (Thunderbird - 1969-1970)
- Article 2071 - 1970 Maverick Speedometer - Noise, Pointer Waver or Inoperative - (All 1970 Mavericks with Automatic Transmissions)
- Article 2072 - Windshield Wipers Do Not Park, Intermittent Function Inoperative - (Fairlane with Optional Intermittent Wiper System - 1970)
- Article 2073 - Speed Control Sensor Binding - (1970 Ford and Thunderbird)
- Article 2074 - Broken Front Seat Back Inboard Pivot Bracket - (1968-1969 Mustang, Ford, Light Truck and Bronco Equipped with Bucket Seats)
- Article 2075 - Window Operating Efforts Too High - (1970 Fairlane Models 63, 65, 66 and 76)
- Article 2076 - Spare Tire Cover Panel Rattle - (1969 Ford Station Wagons)
- Article 2077 - Heat on Floor Pan - (1968-69 F-100-250-350 Series Trucks) (THIS ARTICLE SUPERSEDES ARTICLE 1748, TSB 112, DATED 4-4-69)
