January 1970 - December 1970
Bulletin No. 133 - February 13, 1970 [COMPLETE]
(33 articles)
  • Article 2123 - Disc Brake Noise Correction - (All Car Lines - 1969/70)
  • Article 2124 - Air Brake Flexible Hose - Replacement - (Medium, Heavy or Extra Heavy Trucks with Air Brakes - 1970)
  • Article 2125 - New Improved Shock Absorbers for Improved Ride - (THIS ARTICLE SUPERSEDES TSB NO. 127 ARTICLE NO. 2003 DATED NOVEMBER 21, 1969) - (1968-70 F-100/250)
  • Article 2126 - Power Steering Pump Identification - Ford-Thompson - (All Cars and Light Trucks So Equipped)
  • Article 2127 - Rear Axle Ring Gear Attaching Bolt Retention - (All Current and Past Model Ford Manufactured Rear Axles)
  • Article 2128 - Automatic Transmission Control Valve Spring Identification Chart - (All 1970 Vehicles Equipped with a C6 Automatic Transmission)
  • Article 2129 - Automatic Transmission Governor Attaching Screws - (All 1970 Vehicles with C6 Automatic Transmission)
  • Article 2130 - Engine - Protection of New Units in Storage Awaiting Retail Delivery - (All Vehicles)
  • Article 2131 - Engine - Troubleshooting the Distributor - Modulator System - (Units Equipped with the Disto-Vac System - 1970)
  • Article 2132 - Spark Plugs - Revision to Torque Installation Requirements for 14 MM - (Units Equipped with 351C-2V &4V, Boss 302, 429 CJ, 429 SCJ, and Boss 429 Engines)
  • Article 2133 - Engine - Oil Viscosity Requirements - Boss 302 - (Mustangs Equipped with Boss 302 Engines - 1969-70)
  • Article 2134 - Engine Cylinder Head Gaskets - 428 Police Interceptor (PI) - (All 428 PI - 1966-1969)
  • Article 2135 - Engine Detonation Under Acceleration - (Vehicles Equipped with 429-2V and 429-4V CID Engines except 429 CJ and 429 SCJ - 1970)
  • Article 2136 - Front Engine Mount - Improved - (1968-69 F-B-6000-7000, F-T-8000 Trucks with Caterpillar V-8 Diesel Engines)
  • Article 2137 - Hand Throttle Cable - Excessive Length - (L-LT-9000 Trucks with 8V-71 Detroit Diesel Engines - 1970)
  • Article 2138 - Engine Air Shut Off Control Cable - High Application Effort - ("L" Series - L-LT-9000 Trucks with 8V-71 Detroit Diesel Engines - 1970)
  • Article 2139 - Power Loss During High Altitude Operation - (1970 F-100/250 with 360/390 CID Engine)
  • Article 2140 - Spark Plug Installation Chart - Revision - (All Cars Equipped with 351-4V Engines - 1970)
  • Article 2141 - Alternator - Rectifier Service Kit Parts - (All Models)
  • Article 2142 - Starter - No or Slow Cranking - (All Cars Except Those with 429 CID Engine - 1970)
  • Article 2143 - Starting - Hunt or No Start in Park - All Models with Standard Steering Column - 1968-1969)
  • Article 2144 - Roof Marker Lamp (Teardrop Design) Inadequate Ground - ("L" Series - 1970)
  • Article 2145 - Radio Ignition Noise - (1970 Fairlane with Non-Functional Hood Scoop)
  • Article 2146 - Air Conditioner - Improved Cooling - (Econoline with Factory Installed Air Conditioning - 1969-70)
  • Article 2147 - Power Window System Diagnosis - (All Carlines 1967-1970)
  • Article 2148 - Front Seat Back Crunching Noise - (Thunderbird with Bucket Seats - 1970)
  • Article 2149 - Interior Trim - Front Door Trim Panels and/or Vinyl Squeaks at the "A" Post - (Ford - 1970)
  • Article 2150 - Instrument Panel Crash Pad - Loose - (Ford and Fairlane - 1970)
  • Article 2151 - Rear Seat Back Spring Noise - (Ford Station Wagon - 1970)
  • Article 2152 - Roof Luggage Rack Adjustable Rear Cross Rail - Tight or Binding - (Ford - Fairlane - 1970 Model Station Wagons - So Equipped)
  • Article 2153 - Air Horns - Inoperative - (All "L" Series with R.P.O. Air Horn)
  • Article 2154 - Sun Visor Retention - Improved - ("L" Series Trucks)
  • Article 2155 - Glove Box Door Latch Improvement - R.P.O. Floor Mounted - (All "L" Series with the R.P.O. Glove Box)
