January 1970 - December 1970
Bulletin No. 135 - March 13, 1970 [COMPLETE]
(24 articles)
  • Article 2187 - Noise in Cab During High Speed Cruising - Loud Drumming Type
    (F-100 w/131" WB and Econoline w/123" WB All with 302 CID Engine - 1969-1970)
  • Article 2188 - Sure Track Brakes - Pinion Mounted Sensor
    (Thunderbird - 1970)
  • Article 2189 - Brake Booster Noise or Vehicle Vibrations Upon Brake Application - (SUPERSEDES ARTICLE 2051, BULLETIN 131)
    (1970 Ford Station Wagon, Police Units and F-350 Trucks with Power Disc Brakes Built Prior to 12/15/69)
  • Article 2190 - Rear Brake Retracting Spring Dampner - New
    (All Medium, Heavy and Extra Heavy Trucks with Bendix Wedge Operated Rear Wheel Air Brakes - 1970 and Prior Models)
  • Article 2191 - Tire Tread Wear Pattern - Belted Bias Ply
    (All 1970 Carlines except Thunderbird)
  • Article 2192 - Power Steering Gear Unloader Valve Adjustment - Revision
    (F-B-L-LN-LNT-LT-LTS-500 Through 9000 Trucks with Ross HF-54, HF-64 Integral Power Steering Gears [Except LN-500-750-6000-7000 Models])
  • Article 2193 - Front Axle Knuckle Seal - Improved
    (F-250 4x4 1969-Prior Model)
  • Article 2194 - Range Shift Cylinder - Inoperative
    (Heavy and Extra Heavy Trucks with Fuller RT-910 or RTO-913 Transmissions - 1970 and Past Models)
  • Article 2195 - Automatic Transmission Non-Adjustable Vacuum Diaphragm - SUPERSEDES ARTICLE 2094 TSB 132
    (Vehicles w/C4 & C6 Automatic Transmissions)
  • Article 2196 - Fuel Restriction or Fuel Starvation from Water and/or Dust Entering the Fuel Tank Through the Fuel Filler Vent Notch
    (Mavericks Without Evaporative Emission System - 1970)
  • Article 2197 - Cylinder Head Valve Guide Repair
    (Reference: Special Service Letter 83, 7/21/69 - Special Service Letter Supplement, 10/22/69)
  • Article 2198 - Fan Mounting Bracket & Pulley Assembly - Improved
    (1968-69 F-T-8000 Trucks with Caterpillar V8 Diesel Engines)
  • Article 2199 - Alternator Warning Light and/or Accessories On with Key Removed
    (All 38, 42, 55 & 60 Ampere Alternators Used on 1969 and 1970 Cars and Trucks)
  • Article 2200 - Radio/Ignition Noise - SUPERSEDES ARTICLE 2145 TSB 133
    (Fairlane with Non-Functional Hood Scoop - 1970)
  • Article 2201 - Back Window Grid Wire Repair
    (Ford, Thunderbird, Models So Equipped - 1969-1970)
  • Article 2202 - Power Window Motor Application
    (Thunderbird - 1967-1970)
  • Article 2203 - Front Fender Cracks at Cab Attachment Point
    L Series
  • Article 2204 - Hood Alignment and Reduction of Opening Effort - L Series
    (All L-Series - 1970)
  • Article 2205 - Windshield and Back Window Glass Replacement
    (Vehicles with Butyl Installed Glass - 1968, 1969 and 1970)
  • Article 2206 - Rear Window Defroster (Electrical Grid) - Inoperative
    (Ford and Thunderbird - 1970)
  • Article 2207 - Paint Peeling Off the Radiator Grille Back Panels and Head Lamp Hinges
    (Ford LTD and XL Models - 1969)
  • Article 2208 - Front Fender to Bumper Splash Shield Poor Fit and Appearance
  • Article 2209 - Sun Roof Emergency Crank Handle - Replacement Part Number
    (Thunderbird Equipped with Sun Roof - 1968-1970)
  • Article 2210 - Paint - Special "Diamond Brite" Glamour Finish
