January 1970 - December 1970
(20 articles)
- Article 2211 - Essential Service Tool - Heavy Truck - (Trucks with 42 DP Rear Axle)
- Article 2212 - Brake Squeak Correction - THIS ARTICLE CANCELS AND SUPERSEDES TSB NO. 107 ARTICLE 1639-3 DATED 1/24/69 - (Cortina with Disc Brakes)
- Article 2213 - Brake Booster Noise or Vehicle Vibration Upon Brake Application - THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 2189, BULLETIN 135 - (1970 Ford Station Wagon, Police Units and F-350 Trucks with Power Disc Brakes Built Prior to 12/15/69)
- Article 2214 - Pressurizing Air System from an Auxiliary Source - (All L, LT, LN and LNT Models with Air Brakes - 1970)
- Article 2215 - Toe-In Specification - Revision - (Cortina 1967-1970)
- Article 2216 - Power Steering Control Valve and Power Cylinder Repair Kits - (Maverick, Falcon, Mustang and Fairlane - 1969 and 1970)
- Article 2217 - Power Steering Control Valve Replacement Technique -(Maverick, Falcon, Mustang and Fairlane - 1969 and 1970)
- Article 2218 - Ignition Switch Actuator Rod Retaining Pin Replacement - (All 1970 Fixed Wheel Locking Columns)
- Article 2219 - C4 Automatic Transmission - Revised Throttle Booster Valve Retaining Pin - (All Vehicles with C4 Transmissions - 1970)
- Article 2220 - Automatic Transmission - Loss of Fluid from Filler Tube - (Mustang with 428 CID and C6 Transmission - 1970)
- Article 2221 - Emissions - Air Fuel Ratio Numbers and Idle CO (Car and Truck - 1968 thru 1970)
- Article 2222 - Engine Valve Stem to Rocker Arm Clearance Specification - Revision - (351C CID Engines - 1970)
- Article 2223 - Spark Plug Installation Chart - Revision - (Thunderbird Equipped with 429 CID - 1970)
- Article 2224 - Engine - Rocker Arm - Interchangeability - Cortina - All except Twin-Cam Engine - 1970)
- Article 2225 - Aluminum Cast Air Inlet Connector - THIS ARTICLE SUPERSEDES AND CANCELS TSB NO. 128, ARTICLE 2021 DATED DECEMBER 5, 1969 - (F-T-8000 Trucks Equipped with Caterpillar V-8 Diesel Engines - 1968-1969)
- Article 2226 - Battery Dryness or Excessive Use of Electrolyte - (Thunderbird and Mustangs Equipped with an Ammeter - 1970)
- Article 2227 - Heater Core Leak Diagnosis - (Maverick and Mustang with Standard Heater - 1970)
- Article 2228 - "L" Series Windshield Washer - Improved Performance - (All "L" Series Trucks Built Prior to February 2, 1970 - 1970 Models)
- Article 2229 - Power Window System Diagnosis Supplement - (Thunderbird - 1967-1969)
- Article 2230 - "L" Series Fiberglass Hood - Cracking at Hood Latch Catch - (1970 Models)
