January 1970 - December 1970
Bulletin No. 137 - April 10, 1970
(33 articles)
  • Article 2231 - Brake Locking Devices - (All Trucks Equipped with Hydraulic Brakes)
  • Article 2232 - New One Piece Dust Shield for Rear Wheel Brakes - (All Medium, Heavy and Extra Heavy Trucks with Bendix Wedge Air Brakes - 1966-1970 Models)
  • Article 2233 - Shock Absorber Leakage - Front - (Cortina - 1967-1969)
  • Article 2234 - Clutch - Proper Position for Hydraulic Line - (Cortina with Standard Transmission - 1967-1968)
  • Article 2235 - Clutch Chatter or Slippage Due to Housing Attaching Bolt Seal Oil Leak - THIS ARTICLE SUPERSEDES 2059, TSB 131) - (1970 Fairlane and 1969 Ford Vehicles with 429 CID Engine and Standard Transmission)
  • Article 2236 - Hurst 4-Speed Manual Transmission Shift Control Assembly - (Mustang, Fairlane - 1970)\
  • Article 2237 - Automatic Transmission - Delayed Engagement After Cold Start - (Cortina with Borg Warner Type 35 Automatic Transmission)
  • Article 2238 - Fuel Tank Contamination Due to Rust and/or Corrosion - (1970 Passenger Cars Built Prior to December 31, 1969)
  • Article 2239 - Cylinder Head Gasket - Leaks - (Cortina - 1967-68-69)
  • Article 2240 - Improved Engine By-Pass Oil Filter Hose Routing - L-Series - (1970 "L" Series Trucks Equipped with Horizontal Mounted By-Pass Oil Filters [Luberfiner])
  • Article 2241 - Accelerator Rod Misaligned - L Series - (1970 "L" Series Trucks with Detroit Diesel 6-71 Engine
  • Article 2242 - Engine Air Cleaner Mounting Bracket Pulls Loose From the Dash Panel - L Series - ("L" Series Trucks with Cummins or Detroit Diesel Engines - 1970 Model)
  • Article 2243 - Car Will Not Start - Cold/Wet Weather - (Cortina - 1967-68 Models)
  • Article 2244 - Alternator Regulator Voltage Limiter Control Interchangeability (Lucas) - (Cortina - 1970)
  • Article 2245 - Voltage Regulator Replacement - (Ford - 1968, 1969, 1970)
  • Article 2246 - Ignition Coil - Poor Connection at Coil Battery Terminal - (All Cars - 1970)
  • Article 2247 - Ignition Switch - Unnecessary Replacement - (All Car Lines with Locking Steering Column - 1970)
  • Article 2248 - Ignition Key Warning Buzzer System - (All Car Lines - 1970)
  • Article 2249 - Horn and/or Turn Signal - Intermittent Operation, SUPERSEDES TSB ARTICLE 2116 - (Thunderbird, Ford, Mustang with Tilt Column - 1970)
  • Article 2250 Turn Signal System Revision - Sequential Type - (Thunderbird - 1970)
  • Article 2251 - Ammeter - Improved Indication - (Thunderbird - 1970)
  • Article 2252 - Electrical Accessory Relay - (Ford with RPO Taxi and Police Options - 1970)
  • Article 2253 - Speedometer Cable Rubs Turbocharger Housing - L Series - (1970 L Series with Front Wheel Drive Speedometer and Cummins NTC-335 or NHCT-CT Engines)
  • Article 2254 - Windshield Wiper Blade Installation - L Series - (All "L" Series - 1970)
  • Article 2255 - Vacuum Operated Tailgate Latch Assemblies Inoperative - (Ford - 1970)
  • Article 2256 - Fender Apron Attaching Bolt Contacts Cross Flow Radiator Side Tanks - L Series - (L-LT-LN-LNT 9000 Series Trucks with Diesel Engines - 1970)
  • Article 2257 - Window Regulator Handle Knob Comes Off - (Cortina - 1969)
  • Article 2258 - Window Regulator Knobs Loose or Displaced - (All Models)
  • Article 2259 - Rear View Mirror Looseness - (Carlines with Button Type Rear View Mirror - 1967-1969)
  • Article 2260 - Front Seat Back Cover Damage - (Fairlane - 1968, 1969 and 1970)
  • Article 2261 - Windshield Glass Lower Edge Protector - (Fairlane, Thunderbird - 1970)
  • Article 2262 - Hood Support Rod Grommet Missing - (Cortina - All)
  • Article 2263 - Seat Back Release Knob Loose - (Cortina - 1967-68)
