January 1971 - December 1971
Bulletin No. 159 - February 12, 1971
(25 articles)
  • Article 3287 - A/C Evacuation and Charging Service Tools - (Ford Dual Dealers Servicing Lincoln A/C)
  • Article 3288 - Service Information - 1971
  • Article 3289 - High Speed Tire Shake - (Mustang - 1971)
  • Article 3290 - NVH Diagnosis - Tire Pressure - (All Car Lines)
  • Article 3291 - Air Discharge Line Leakage at Air Compressor Fitting - (All Trucks Equipped with Air Brakes - 1970-71 Trucks)
  • Article 3292 - Dana 44 Front Driving Axles - Bronco - Lubrication - (Bronco - U100 Series - 1971)
  • Article 3293 - Universal Joint - Improved Constant Velocity - CANCELS AND SUPERSEDES TSB 155, ARTICLE 3194, DECEMBER 11, 1970 - (All Bronco - 1966 through 1970)
  • Article 3294 - Lubricant Leakage from Transmission Vent - (L, LT, LTS, LN & LNT 9000 Series Trucks with Spicer 8552A, p-8516-3B and P-8716-3A Transmissions - 1970 Models)
  • Article 3295 - Erratic or No Upshifts - (Mustang, Torino, Maverick with 8-Cylinder Engine and Automatic Transmission - 1971)
  • Article 3296 - Chatter In Reverse - No Reverse - Erratic Shifting - No Drive - (Pinto with C4 Transmission - 1971)
  • Article 3297 - Brakes - Uneven Braking - (Pinto, Maverick - 1971)
  • Article 3298 - Initial Ignition Timing Revision - (1971 Econoline E-300 with 302-2V Engine and 1971 800 through 900 Series Trucks with 401 V-8 Engine)
  • Article 3299 - Dipstick Tube Leak at the Oil Pan - Light Truck - (Econoline 302 CID Engines - 1971)
  • Article 3300 - Accelerator Linkage - Slow return to Idle - (All Passenger Cars with 8 Cylinder Engines - 1971)
  • Article 3301 - Radiator Coolant Loss - (Pinto 1971 - 2.0 Liter Only)
  • Article 3302 - Alternator Wiring Harness Retaining Strap Repositioning - L Series - ("L" Series Truck - All)
  • Article 3303 - Horn Blows Continually - (All Carlines - Two-Spoke Steering Wheel Without Speed Control - 1971)
  • Article 3304 - Installation of Inline Check Valve to Protect the Heater Core - "C" Series - (C-Series with "FT" Engines - 1970-71)
  • Article 3305 - Insufficient Heat - (Ford with Manual A/C System - 1971)
  • Article 3306 - WIndow Operating Effort - (All Car Lines)
  • Article 3307 - Back Window Grid wire - Diagnosis and Repair; THIS ARTICLE SUPERSEDES ARTICLE 2201, TSB 135 - (Ford-Thunderbird, Models So Equipped - 1970-1971)
  • Article 3308 - Jacking Instructions - Front Bumper - (Thunderbird Equipped with R.P.O. Front Bumper Guards - 1971)
  • Article 3309 - Radiator Grille - Retaining Screws Loosen - ("L" Series Truck - All Models - 1970-71)
  • Article 3310 - Hood Reinforcement - To Prevent Excessive Wear Due to Contact with Fender Seal - L Series - (Louisville Truck - Series LN-LNT-LTS 500/900 - 1970-71)
  • Article 3311 - Rework of Service Radiator Grille Front End Assembly for P.T.O - L-Series - (All "L" Series with Front-Mounted P.T.O. - 1970-71)
