January 1971 - December 1971
(26 articles)
- Article 3312 - Steering Gear Assembly - CANCELS ARTICLE NO. 3221, BULLETIN 156 DATED DECEMBER 18, 1970 - (Pinto - 1971)
- Article 3313 - Front Wheel Tubeless Flotation Tire Data - (L-Series Tandem Axle Trucks with 16,000, 18,000 and 20,000-Pound Front Axles)
- Article 3314 - Rack & Pinion Steering Gear - Diagnostic Procedure - (Pinto 1971)
- Article 3315 - Oil Filter & Pump Housing for Power Steering Pump - New - (Ford, Torino, Mustang, Maverick, Thunderbird with XR50 Power Steering Gear - 1969/1971)
- Article 3316 - Forward Axle Output Shaft Bearing - New - (Extra Heavy Trucks Equipped with Rockwell SLHD and SQHD Tandem Axle - 1971)
- Article 3317 - Transmission Shift Rod Seals - Damaged or Missing - SUPERSEDES ARTICLE 3117, BULLETIN 151 - (Pinto with Ford of Germany Four-Speed Manual Transmission [Model 71WG-AB] - 1971)
- Article 3318 - C4 Automatic Transmission - Valve Body Separator Plate Gasket - Part Number Revision - SUPERSEDES ARTICLE 3252, BULLETIN 157 - Pinto with C4 Automatic - 1971)
- Article 3319 - FMX Automatic Transmission - Output Shaft Bearing Change - Part Numbers Revision - SUPERSEDES ARTICLE 3253, BULLETIN 157 - (Ford, Torino, Mustang with FMX - 1971)
- Article 3320 - Camshaft Drive Belt - (2000cc Pinto - 1971)
- Article 3321 - Pre-Delivery Valve Lash Adjustment - (1971 Pinto w/2000cc Engine)
- Article 3322 - Cylinder Head Flatness Specification - Revised - (240-300 CID Engine - All Years)
- Article 3323 - Hard Cranking - Cold Weather - (Mustang with 351C HO Engine - All)
- Article 3324 - Rough Idle - (Pinto with 2000 CC Engine and Weber Carb. 5200 CC - 1971)
- Article 3325 - 5200 carburetor (Weber-Staged 1V) - Hesitation When Cold - (Pinto with 2000 CC & Automatic - 1971)
- Article 3326 - Carburetor Fuel Inlet Needle Seat - Insufficient Torque - (Pinto - 2000 CC Engine with Weber Carb. 5300-C - 1971)
- Article 3327 - Stall or Stumble on Acceleration - (Maverick wit 200 CID Engine and Automatic Transmission - 1971)
- Article 3328 - 2V Carburetor - 400 CID - Surge and Hesitation - (Ford with 400 CID - 1971)
- Article 3329 - Air Cleaner Cover with a 6-Slot End Opening - L-Series - New - (L-LT-LTS, LN-LNT-8000-9000 Trucks with Caterpillar V8 or Cummins NH 230 & 250 - 1970)
- Article 3330 - Rear Lamp Wiring Harness - Proper Routing - (Ford - All Models - 1971)
- Article 3331 - Wiring Repair - (All Car Lines - 1970, 1971)
- Article 3332 - Under-hood Wiring Rubs Hood Stabilizer Bracket - ("L" Series Truck - All - 1970-71 Built Prior to 1-29-71)
- Article 3333 - Front Seat - Increasing Cushion Height (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 3284, TSB 158, DATED JANUARY 29, 1971) - (Mustang Models 63-65D - 1971)
- Article 3334 - Seat Belts - Special Long Length (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE NO. 2299, TSB 138, DATED APRIL 24, 1970) - (All Carlines - 1970)
- Article 3335 - Rear Seat Back Top Cover Wrinkled - (Pinto - All Models - 1971)
- Article 3336 - Front Door Window Will Not Lower From Full Up Position - (Ford - Four-Door Models 53 and 57 - 1971)
- Article 3337 - Water Leaks - Luggage Compartment Door - (Pinto - 1971 runabout Model [3-Door])
