January 1971 - December 1971
Bulletin No. 162 - March 26, 1971
(25 articles)
    - Article 3365 - Disc Brake Lining Replacement - (All Passenger Cars with Disc Brakes)
    - Article 3366 - Clutch Assist (Over Center) Spring - Noise During Pedal Operation - (Mustang with Manual Transmission - 1971)
    - Article 3367 - Clutch Pressure Plate Attaching Bolts - (Pinto with 1.6L Engine - 1971)
    - Article 3368 - Floor Shift Lever - Service Procedure - (Pinto with 4-Speed Manual Transmission)
    - Article 3369 - Input and Output Shaft Bearing - Inspection Procedure - (Manual Transmission)
    - Article 3370 - Delayed Drive to Reverse Engagement - SUPERSEDES TSB 146, ARTICLE 2980, DATED AUGUST 7, 1970)
    - Article 3371 - Engine Front Mount Installation - (L, LT, LNT, LTS-9000 Trucks)
    - Article 3372 - Oil Filler Cap Assembly - Service Replacement - (Pinto with 2000cc Engine - 1971)
    - Article 3373 - 351 C-HO Engine - (Boss Mustang - 1971)
    - Article 3374 - Initial Ignition Timing Revision - (Pinto - 2000cc Engine with Automatic Transmission - 1971)
    - Article 3375 - Rough Engine Idle - (Pinto with 2.0L Engine, Air Conditioning and Weber Carburetor Tag - D12F-FA Automatic Transmission and D12F-GA Manual Transmission - 1971)
    - Article 3376 - Carburetor - Diagnosis Guide - (Pinto - 1971)
    - Article 3377 - Carburetor Deceleration Valve - Operation and Service - (Pinto - All Engines - 1971)
    - Article 3378 - Weber Model 5200C Carburetor - Lubrication Guide and Service Interval - (Pinto - 2000cc Engine - 1971)
    - Article 3379 - New Radiator to Dash Support Brace Insulators - ("L" Series Trucks - 1970)
    - Article 3380 - Radiator Pressure Cap Specification - (Truck Shop Manual - 1971)
    - Article 3381 - Alternator - Mounting Bolt Breakage - (Pinto with 2.0L Engine - 1971)
    - Article 3382 - Speedometer System Service - Sensors & Lower Cable (SUPERSEDES ARTICLE 2183, TSB 134) - (Ford, Thunderbird - 1970)
    - Article 3383 - Radio Feed Wire Installation - Radio Accessory Kit - THIS ARTICLE SUPERSEDES ARTICLE 3101, TSB NO. 150 - (Pinto - 1971)
    - Article 3384 - Dash Panel Wiring Assembly - Repair Procedure - (Pinto - Equipped with 2 Liter Engine - 1971)
    - Article 3385 - Heater - Insufficient Heat - (Pinto - Standard Heater - 1971)
    - Article 3386 - Heated Back Window - Indicator Light Pulsates - (Torino, Mustang, Thunderbird - All with Heated Back Window - 1971)
    - Article 3387 - Remote Control Mirror - Hole in Door Outer Panel Visible After Removing Remote Mirror - CANCEL ARTICLE NO. 1913, TSB NO. 120, AUGUST 1, 1969 - (F-Series with Factory Installed Remote Control Mirror)
    - Article 3388 - Windshield Wiper - Articulating link Retainer Clip Service Procedure - (Ford, Mustang, Torino - 1971)
    - Article 3389 - Frame to Fender Apron Splash Shields - Service Procedure - (Ford - 1971)
