January 1972 - December 1972
Bulletin No. 32 - December 15, 1972
(12 articles)
  • Article 285 - Wind Noise at Top of Windshield - Right or Left Sides - (1973 Mercury)
  • Article 286 - Mini-Vent System - Troubleshooting Guide - (1972 Ford/Mercury and 1972-73 Lincoln Models Equipped with Mini-Vents)
  • Article 287 - Speedometer Pointer Waver and/or Noise - (1973 Ford/Mercury with Speed Control)
  • Article 288 - Power brake Booster - Master Cylinder "Clunk" Noise - (1973 Thunderbird/Lincoln/Mark IV and Ford/Mercury Station Wagons)
  • Article 289 - Power Steering "Moan" Noise - (All 1973 Ford; 1973 Mercury with 351 and 400 CID Engines Only)
  • Article 290 - Fuel Starvation - (1973 All Car Lines with 351W, 429 and 460 CID Engines except P.I.)
  • Article 291 - Shift Effort - (1970-72 Maverick/Comet with 3-Speed Standard Transmission and Column Shift)
  • Article 292 - Rear Wheel Brake Squeal - (1972 and Past Model Heavy and Extra Heavy Trucks with S-Cam Operated Rear Air Brakes)
  • Article 293 - Clutch Release Arm Contacts the Engine Support (Left Hand) - (1970-72 Model C and CT 900 Trucks)
  • Article 294 - Transmission Extension Housing Oil Leaks - (G-100 Postal Trucks)
  • Article 295 - Engine By-Pass Oil Filter Element Relocation - (W-WT9000 Trucks with Four 6 Volt Batteries)
  • Article 296 - Transmission Locks in Low or Reverse Gear - (1970-72 Model All "L" Series Trucks Equipped with Clark 280 Series Transmissions)
