January 1972 - December 1972
Bulletin No. 24 - September 22, 1972
(19 articles)
  • Article 135-S - (SUPPLEMENT) Two-Spoke Pad - Horn Blowing Assembly - (1970-73 All Car lines So Equipped)
  • Article 223 - Courtesy Light Bleed Through - (1973 Mercury)
  • Article 224 - Front Seat Back Cover Wrinkles - (1973 Thunderbird with Split Bench Front Seat)
  • Article 225 - Fuel Filler Door Noise - (1973 Ford, Mercury)
  • Article 226 - Starter Brush Spring Breakage - (1972 All Passenger Cars with 4½" Starters
  • Article 227 - Front End Sheet Metal Shake - (1973 Ford, Mercury)
  • Article 228 - Steering Shaft Grounding - (1973 Ford, Torino and Thunderbird; 1973 Mercury, Montego and Mark IV)
  • Article 229 - Tip-in-Moan - (1973 Mustang/Cougar Except Convertible)
  • Article 230 - Rear Axle "Chuckle" Noise - (1972 All Car Lines with Ford Manufactured Axle [Standard & Traction Lok])
  • Article 231 - New Vacuum Can Retaining Clip - (1972-73 All Vehicles with C-6 Automatic Transmission and "Push-In" Type Vacuum Can)
