January 1972 - December 1972
Bulletin No. 27 - October 20, 1972
(13 articles)
  • Article 241 - Door Pull Handle - Removal and Installation - (1972-73 Lincoln Town Car Model 53)
  • Article 242 - Door Window Regulator Assembly - Vibration Noise - (1972 Thunderbird, Torino, Pinto)
  • Article 243 - Door Closing Efforts - (1971-72 Capri)
  • Article 244 - Power Seat Tracks - Noisy and/or Restricted Travel - (1973 Ford/Mercury)
  • Article 245 - Ignition Noise in FM Radio Reception - (1972 Thunderbird, Lincoln Mark IV)
  • Article 246 - Power Door Lock System - Installation of Circuit Breaker - (1972 Thunderbird, Lincoln Mark IV)
  • Article 247 - Seat Sensor Switch Replacement - (1972 Thunderbird/Lincoln/Mark IV with Split Bench Seat)
  • Article 248 - Stiffness in Gear Shift Lever Action - (Part Number Change) - (1972 Capri V-6 2600cc equipped with C-4 Automatic Transmission)
  • Article 249 - Oil Leakage at the Oil Filter Gasket Sealing Surface - (1973 Vehicles with 351W Engines)
  • Article 250 - Suppression of rear Axle Noise - (1972 Ford/Mercury with 400-2V and 429-4V Engines - 2.75:1 and 3.00 9" Axle Ratios Only)
  • Article 251 - Improved Steering Ball Joints - (1972 F-100 4x4 and 1971-1972 Bronco)
  • Article 252 - Side Seal Leakage at Rear Main Bearing Cap - (1972 Courier with Engine Serial Numbers Below T49541)
  • Article 253 - "Buzzing" Noise in Third or Fourth Gear - (1972 F-100-350 with 4 Speed Warner T-18 Transmission)
