Article 1163 - Correction to 1968 Passenger Car Maintenance and Lubrication Manual
TSB #76 - September 29, 1967
(All 1968 Passenger Cars)
Upon receipt of the 1968 Passenger Car Maintenance and Lubrication Manual, the following corrections should be made immediately to the Pre-Delivery Sequence Guide section:
    • "UNDER HOOD - ENGINE OFF" - Add "Drive belt tensions"
    • "ON HOIST" - Delete "Disc brake caliper-to-spindle bolt*
    Add a new heading "ALIGNMENT STALL" between "ON HOIST" and "ROAD TEST" with the operation "Front wheel toe-in" as the lone check-off item.
