Article 1012 - New Tachometer Drive and Cable
TSB #61 - March 10, 1967
(1963-66 Dagenham Engine Equipped C & N 6000/7000)
A new tachometer drive and cable is now available for the models listed, to provide longer service life than the cable and the right angle drive previously used.
On a complaint basis the new drive can be installed in the following manner:
N Series: N6000/7000 WITHOUT POWER STEERING
1. Remove old cable and angle drive.
2. Discard the three (3) 1/4 "-20 x 1-1/4 " bolts.
3. Install the new drive assembly with three (3) 1/4 "-20 x 3/4" bolts and lockwashers.
4. Install new cable and route as shown in Illus. SI 186.
5. Torque cable nut to 18 to 25 inch pounds.
C Series: C6000/7000 WITHOUT POWER STEERING
1. Remove old cable, angle drive and cable support bracket.
2. Discard the three (3) 1/4 "-20 x 1-1/4" bolts.
3. Install the new drive assembly with three (3) 1/4 "-20 x 3/4 bolts and lock-washers.
4. Install new cable and support at engine and radiator support as shown in Illus. SI 187.
C & N Series WITH POWER STEERING
The instructions are the same for these units except a right angle adapter must be used in order for the cable to clear the power steering pump. The adapter mounts on top of the new straight drive.
The following table lists part numbers of the pieces needed to perform this modification.
PART NAMEPART NUMBERAPPLICATION
Tach Drive Gear Engine UnitC6TZ-17373-AC&N 6000/7000
Right Angle Adapter (Units with Power Steering Only)C6TZ-17A270-BC&N 6000/7000
Cable AssemblyC6TZ-17365-GC Series
Cable AssemblyC6TZ-17365-HN Series
Illus. 1186
Illus. 1187
WARRANTY STATUSREIMBURSABLE
Oper: 17360-A - N, NT Series; C, CT Series
17365-A - F&T (N) Series; C, CT Series
Time: Total N Series — 0.9 hrs.
Total C Series — 1.2 hrs.
