Article 1112 - Field Repair of Stripped Seat Belt Floor Attachments
TSB #70 - June 23, 1967
(All Ford Vehicles)
UNDER CONSTRUCTION
In the event the seat belt anchor plate or attaching bolt threads are stripped, through improper service techniques, the following two basic methods of repair are recommended:
1. On single belt floor mounts, the threads in the seat belt mounting plate
are to be drilled out and retapped to accomodate a 1/2-13 bolt (slightly larger in diameter than the existing bolt).
2. On multiple belt floor mounts, in addition to drilling and tapping the hole, a locking nut is to be added to the seat belt anchor from the underside of the floor pan.
Refer to the following parts listing, application charts and illustrations relative to the repair of seat belt floor
attachments. IT SHOULD BE NOTED THAT THE INDICATED STANDARD PARTS REPLACEMENT MUST BE ADHERED TO, WITH NO SUBSTITUTIONS, IN ORDER TO MAINTAIN PROPER SPECIFICATIONS. In addition, the end of the seat belt attached to the floor must be positioned as illustrated.
In order to perform the aforementioned corrective procedures, it is necessary to procure the following components on an as required basis.
381900-S36Bolt 1/2 - 13 x 1-1/4 Hex Head
381901-S36Bolt 1/2 - 13 x 1-1/2 Hex Head Shoulder
381990-S36Bolt 1/2 - 13 x 2.25 Hex Head Shoulder
353471-SWasher 1/2 Flat .53 I. D. 1.00 0. D. x .190 Thick
381559-S2Washer 1/2 Flat Serrated
356476-SWasher Flat .59 I. D. 1.31 0..D. x .190 Thick
354959-SWasher - Rubber
55828-SNut 1/2-13 Hex Lock
IMPORTANT NOTE: Do not substitute above-listed standard attaching parts. Only Ford Motor Company certified parts should be used.
SEAT BELT FLOOR ATTACHMENTS 1967 CAR LINES INDEX
SINGLE BELT APPLICATIONS
CAR LINESMODELSEAT BELT ATTACHMENT LOCATIONPOSITION CODEFIGURE NUMBER
Sketch of Seat Belt Floor
Attachment and Code
1
FordAllFront Inboard and OutboardA & B2
Ford57-63-76 54-62-71Rear Inboard & OutboardC & D3
Ford71Side Facing Seat & Rear Facing SeatE & F3
Mustang - Falcon - FairlaneAll Except 76Front OutboardA4
Mustang - Falcon - FairlaneAllFront InboardB4
MustangAll Except 63Rear OutboardC5
MustangAll ModelsRear InboardD5
Mustang63Rear OutboardC6
Fairlane76Front OutboardA7
Mustang76Front OutboardA8
Falcon - Fairlane71-54-62 63-76Rear Inboard — OutboardC & D3
Fairlane71Rear Facing SeatE & F3
ThunderbirdAllRear Inboard & OutboardC & D3
ThunderbirdAllFront Inboard & OutboardA & B9
MULTIPLE BELT APPLICATIONS
ATTACHMENT LOCATION
FordAll With Double Belt AttachmentFront InboardB10
Ford — Mustang —
Falcon — Fairlane
All With Triple Belt AttachmentFront InboardB11
Mustang - Falcon — FairlaneAll With Double Belt AttachmentFront InboardB12
Ford — Mustang — Falcon -
Fairlane — Thunderbird
All With Double Belt AttachmentsRear InboardD13
SEAT BELT FLOOR ATTACHMENT LOCATION - 1967 MODELS
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
Figure 8
Figure 9
Figure 10
Figure 11
Figure 12
Figure 13
