January 1974 - December 1974
Bulletin No. 60 - January 18, 1974
(25 articles)
  • Article 232-S - POWER STEERING DIAGNOSIS - (ALL CAR LINES So Equipped)
  • Article 490 - SERVICE LABOR TIME STANDARDS - REVISIONS
  • Article 491 - BROKEN INTERIOR DOOR HANDLE - (1973 CAPRI)
  • Article 492 - FRONT CENTER PASSENGER SEAT BELT - INTERLOCK DELETION - (1974 All Passenger Vehicles So Equipped)
  • Article 493 - IMPROVED ENGINE COOLING - (1974 MAVERICK/COMET with A/C and/or V-8 Engines)
  • Article 494 - LUGGAGE COMPARTMENT DOOR BINDS DURING OPENING AND CLOSING - (1974 MUSTANG II - Model 69)
  • Article 495 - SEAT BELT WEBBING CANNOT BE PULLED FROM LAP BELT RETRACTOR - (1974 ALL MODELS Except Capri)
  • Article 496 - SHOULDER STRAP "COMFORT CLIP" MISSING - (1974 ALL CAR LINES Except Capri)
  • Article 497 - LOAD LEVELING SYSTEM - AIR LEAK DIAGNOSIS - (ALL VEHICLES So Equipped)
  • Article 498 - STEERING COLUMN BOOT MOAN - (1973-74 TORINO AND THUNDERBIRD, 1973-74 MONTEGO AND MARK IV, 1974 COUGAR)
  • Article 499 - HEAD LIGHT SWITCH AND/OR POTENTIOMETER REPLACEMENT -(LIGHT BELAY SYSTEM) - (1974 THUNDERBIRD, 1974 LINCOLN AND MARK IV So Equipped)
  • Article 500 - HEADLIGHT SWITCH - PARKING LAMP TERMINAL DELETION - 1969 AND PRIOR VEHICLES So Equipped)
  • Article 501 - RADIO ANTENNA INSTALLATION - (1974 PINTO)
  • Article 502 - REAR LAMPS - WATER ENTRY - (1973 MERCURY, All Models Except 71)
  • Article 503 - SOLID STATE IGNITION - (1973-74 ALL VEHICLES So Equipped)
  • Article 504 - 1974-1/2 AUTOMATIC TRANSMISSION (Model 74DT-BKB) - (1974-1/2 MUSTANG with 2.3L Engine)
  • Article 505 - ROUGH ENGINE IDLE - DIAGNOSIS - (PINTO/CAPRI with 2000 cc Engine)
  • Article 506 - THINNER REAR AXLE PINION BEARING SHIMS FOR 8.7" RING GEAR AXLES - (ALL CAR LINES So Equipped)
  • Article 507 - FRONT PUMP HOUSING BUSHING INSTALLATION - (1974 AND ALL PRIOR VEHICLES with C-6 Automatic Transmission)
  • Article 508 - PROCEDURE FOR LOCATING TDC AND 6° BTDC TIMING MARKS ON 1974 2300cc CRANKSHAFT PULLEYS - NOT SO MARKED - (1974 MUSTANG AND PINTO 2300 cc Engine)
  • Article 509 - UPPER SPEEDOMETER CABLE BREAKAGE - (1972-73 "C" SERIES TRUCK)
  • Article 510 - ENGINE EMISSION DECALS - ERROR IN DISTRIBUTION POINT GAP SPECIFICATION - (1974 FT AND SD TRUCK ENGINES)
  • Article 511 - INCORRECT OIL LEVEL INDICATOR (Dipstick) - (1973 F-250/350 SERIES with 460 CID Engines)
  • Article 512 - INDUCTION BACKFIRE VALVE - (1973 Series Trucks Equipped with 401, 477, and 534 CID Engines)
  • Article 513 - NEW SPIN-ON FUEL FILTER ASSEMBLY - (1973 Trucks with 401, 477, and 534 CID Engines)
