(Pinto - 1971)
Pintos with the German four-speed transmission found to be leaking oil at the interface of the extension house and case, the back-up light switch, the shift handle opening or at the plug in the shift tower turret should be corrected as follows:
- 1. Coat the rear face of the case with contact adhesive B9AE-19B508-A.
2. Let the contact adhesive set for approximately one minute and carefully place the new gasket, D1FZ-7086-B, on the case.
3. Coat the face and pilot of the extension housing with the contact adhesive and complete the assembly of the transmission.
PARTS:
Description | Part Number | Class | Avail. |
Gasket & Seal Contact Adhesive | B9AE-19B508-A | A | 12-16-70 |
Extension Housing Gasket | D1FZ-7086-A | C | 12-16-70 |
WARRANTY STATUS: Reimbursable within provisions of Warranty and Policy Manual.
Operation: With 1600 CC - SP-7650-B-71; With 2000 CC - SP-7650-A-71
Time: With 1600 CC - 2.0 Hrs.; With 2000 CC-2.1Hrs.
