(F-B-C-500-750; F-B-C-6000-8000 Trucks)
New fan shrouds are available as a product improvement which are moulded of reinforced polyester resin. The new material provides improved component durability.
Following are the new shroud part numbers and usage:
PARTS:
New Part | Vehicle Model | Engine | Class | Avail. |
D1TZ-8146-D | F-B-500-750 | 8 Cylinder Gas | A | OK |
D1TZ-8146-B | F-B-6000-7000 | Cat. 150-175 hp | A | OK |
D1TZ-8146-C | F-7000 | Cat. 200 hp | B | OK |
D1TZ-8146-B | C-550-750 C-CT-800 | 8 Cyl. Gas | A | OK |
D1TZ-8146-B | C-6000-7000 | Cat. 150-175 hp | A | OK |
D1TZ-8146-B | C-500-600 | 300 H.D. 6 Cyl. | A | OK |
D1TZ-8146-C | C-7000-8000 | Cat. 200 hp Std. Cooling | B | OK |
D1TZ-8146-C | C-6000 | Cat. 150 hp Extra Cooling | B | OK |
D1TZ-8146-C | C-6000-7000 | Cat. 175 hp Extra Cooling | B | OK |
PRODUCTION CORRECTION: 10-26-70.
WARRANTY STATUS: INFORMATION ONLY
