January 1968 - December 1968
(13 articles)
- Article 1255 - Door Lock Remote Control Rod Retention - (1967 Cortina - All Models)
- Article 1256 - Leece-Neville 65-Ampere Alternator Front Bearing - (Medium, Heavy and Extra Heavy Truck)
- Article 1257 - Luggage Compartment Lock Malfunction - (1967 Cortina - Model "C")
- Article 1258 - Proper Use of Sealer - Repair of Windshield and Backlite Water Leaks - (All Car Lines - All Models)
- Article 1259 - Instrument Panel Ash Receptacle Retention - (1968 Thunderbird Equipped with Bench Seat)
- Article 1260 - Loose Inside Rear View Mirror - (1967-68 All Car Lines with Windshield Mounting)
- Article 1261 - Floor Carpet Damage - (1968 Cortina - All Models)
- Article 1262 - Potential Radiator Damage Due to Incorrect Mounting Bracket - (All 1968 Thunderbirds Built Prior to September 7, 1967)
- Article 1263 - Inoperative Turn Signal Switches - Fixed and Tilt Column - (All 1968 Car Lines)
- Article 1264 - Limited Clearance - Shift Lever to Steering Wheel - (1968 Ford and Fairlane Equipped with Column Mounted Standard Transmission)
- Article 1265 - Loose Fiberglass Rail Attachments - (1968 Ford and Fairlane - Squire Models)
- Article 1266 - Seal - Front Clutch Sun Gear Oil - Rear MX-FX Three Speed Automatic Transmission - (1967 Fords Equipped with MX or FX Automatic Transmissions)
- Article 1267 - Correction to 1968 Ford-Mercury and Cougar, Fairlane, Falcon, Montego and Mustang Shop Manuals - (Ford, Fairlane, Falcon and Mustang)
