January 1968 - December 1968
Bulletin No. 085 - February 9, 1968 [COMPLETE]
(15 articles)
  • Article 1269 - Oil Consumption Originating From the Crankcase Ventilation System - (All 1967 Vehicles Powered with 352, 390 or 428 CID Engines, Except Cougar and Mustang)
  • Article 1270 - Dislodged Transmission Filter Assembly, FMX Automatic Transmission Models PHA-B, C - (1968 Ford with 302 CID Engine Built Prior to February 1, 1968)
  • Article 1271 - Reduction of Heater Core Water Flow or Pressure - (All 1966, 1967 and 1968 Vehicles Built Prior to December 15, 1967 and Equipped with 289 or 302 CID Engines)
  • Article 1272 - Front Pump Check Valve (Correction to 1968 Ford-Mercury Shop Manual) - (1968 Ford with FMX-MX Automatic Transmission)
  • Article 1273 - High Shift Efforts and Noise - All 5 Speed Transmissions (Spicer, Fuller, Clark, New Process) - (All Trucks Equipped with all 5 Speed Transmissions - Spicer, Fuller, Clark, New Process)
  • Article 1274 - Excessive Front Seat Back Angle or Deflection - Addition to Article #1233, TSB #81 Dated December 8, 1967) - (1968 Bronco - All Models Equipped with Bucket Seats)
  • Article 1275 - Ignition Switch Relocation - (1967 "W" Series)
  • Article 1276 - Intermittent Blower Motor Operation - (1968 Ford Equipped with Integral Air Conditioning Heating System)
  • Article 1277 - Ownercard Imprinter Replacement Rollers - (All Models)
  • Article 1278 - Dorset Diesel Engine Sleeve Remover & Installing Tools - (All Dorset Diesel Engines)
  • Article 1279 - Excessive Blower Motor Noise on Low Blower Speed - (1968 Thunderbird Equipped with Automatic Temperature Control)
  • Article 1280 - Identification of Correct Crankshaft Pulley Bolts Used in 289/302 CID Engines Regardless of Accessories to Prevent Bolt Breakage - (All Vehicles Built Prior to January 15, 1968 and Equipped with 289 and 302 CID Engines)
  • Article 1281 - Premature Rear Brake Lining Wear Correction - (All 1965-1967 Ford Station Wagon Models)
  • Article 1282 - Change in Lubricating Oil Specifications - (1967-1968 242 and 363 CID Ford Dorset Diesel Engines)
  • Article 1283 - Momentary Engine Hesitation on Acceleration and/or Rough Engine Idle - (1968 390-4V GT Engine Equipped Vehicles [Holley Carburetor] Built Prior to Approximately December 15, 1967)
