January 1968 - December 1968
Bulletin No. 086 - February 23, 1968 [COMPLETE]
(19 articles)
  • Article 1284 - Road Splash and Mud Accumulation at Door Entry Step - (1967, 1968 F-100-350)
  • Article 1285 - 1968 Driveline U-Joint Usage - (1968 - All Light Trucks)
  • Article 1286 - Headlining Sag - ("New Cortina" Range)
  • Article 1287 - Back-up Light Switch Adjustment - (1967 and 1968 Model C Cortina)
  • Article 1288 - Manual Transmission Hard Shift Caused By Improper Clutch Operation - (1968 F-100-250-350 4x2 and F-100-250- 4x4, 1967 F-100-250 4x2)
  • Article 1289 - Water Leak at the Cowl Air Duct Attachment - (1968 Fairlane, Falcon and Mustang - All Models)
  • Article 1290 - High Quarter Window Operating Efforts and/or Damaged Vertical Weatherstrip - (1968 Models 63 and 65)
  • Article 1291 - Glove Box Door Adjustment - (Cortina Model "C")
  • Article 1292 - Inadequate Battery Cable Termination - (All 1968 Vehicles Built Prior to November 15, 1967)
  • Article 1293 - Premature Brake Drum Wear and/or Noise During Brake Application - (All 1965 through 1968 F-100/350)
  • Article 1294 - Excess Fuel Cable Return Spring - (1967-68 C, B, N P-5000 & F 6000/7000 Vehicles Equipped with 363 CID Dorset Diesel Engines)
  • Article 1295 - Antenna Installation - (1968 Ford)
  • Article 1296 - Engine Crankcase Oil Viscosities - (1967-68 242 and 363 CID Dorset Diesel Engines)
  • Article 1297 - Correction to Shop Manual - Speed Control Wiring Diagrams and Set-Speed Switch Diagnosis - (1968 Ford and Mustang)
  • Article 1298 - Use of Automatic Transmission Fluid Meeting Ford Motor Company Specification M-2C33-F - (All Automatic Transmissions)
  • Article 1299 - 4 Speed Transmission Noise Diagnosis - (All Trucks with 4 Speed Transmissions)
  • Article 1300 - Front Fender Grounds to Bumper - (1968 Fairlane - All Models)
  • Article 1301 - Tool Tip - Oil Seal Garter Spring Retention - (All Vehicles)
  • Article 1302 - Driveline "Clunk" or "Snap" - (1965-1968 F-100-F-350; P-350-P-500; P-3500-P-5000; E-100-300)
  • Article 1303 - New Fuel Tank Straps - (1967 W & WT-1000 Equipped with 100 Gallon Rectangular Fuel Tanks)
