January 1968 - December 1968
Bulletin No. 101 - November 1, 1968 [PARTIAL]
(22 articles)
  • Article 1514 - Steering Shaft Rattle or Noise - (All Passenger Car Lines with Collapsible Columns)
  • Article 1515 - C6 Automatic Transmission Converter Stator Support Assembly Check Ball Sealing (Supersedes and Modifies TSB #87, Article 1305 Dated March 8, 1968) - (All 1967-68 Units Equipped with C6 Automatic Transmission)
  • Article 1516 - Loss of Coolant - (1968 Ford Galaxie with 302 C.I.D. Engine and Air Conditioning)
  • Article 1517 - Air Cleaner Tue Assembly - Field Fabrication - (1966½-1968 W Series Trucks)
  • Article 1518 - Automatic Transmission Band Adjustment Schedule Revision - (1969 Passenger Cars Except Police, Taxi and Vehicles with 427-4V and 428-4V Cobra Jet Engines)
  • Article 1519 - All Radio Speakers Become Inoperative During Fader Control Operation - (1969 Ford with AM Radio and Rear Speakers)
  • Article 1520 - Improperly Torqued Engine Mounts - (1968 Fairlane and Mustang with 8-Cylinder Engine)
  • Article 1521 - C Series Cab Air Leaks - (C Series Trucks)
  • Article 1522 - No Crank Complaints on 429 C.I.D. Units - (1968 and 1969 Thunderbirds and 1969 Fords)
  • Article 1523 - Noisy or Poor Sounding Door Radio Speaker - (1969 Ford Equipped with AM/FM or AM Stereo Tape Radio)
  • Article 1524 - Tilt Cab Support to Vacuum Pump or Air Compressor Discharge Fittings Interference - (C-6000-7000 with Caterpillar Mid-Range Engines)
  • Article 1525 - Oil Pressure Gauge Reads High - (1969 Mustang - Cobra Jet)
  • Article 1526 - Air Cleaner Vacuum Access Tube Cover - (F-B-6000 & 7000 Trucks with Caterpillar Mid-Range Diesel Engines Without Vacuum Brakes)
  • Article 1527 - Pivot Window Outer Frame Weatherstrip Distortion - (1969 Econoline Built Prior to May 31, 1968)
  • Article 1528 - Improved Accessory Relay Assembly - (1967-1968 W Series Trucks Built Since Serial No. A84000)
  • Article 1529 - Air Cleaner Connector to Engine Gasket - (F-T-8000 Trucks with Caterpillar Mid-Range Diesel Engines)
  • Article 1530 - Damaged Exhaust Outlets to Dual Exhaust Systems - (1969 Fairlane/Torino Passenger Cars Equipped with 427 CID Engine or the 428 CID Cobra Jet Engine)
  • Article 1531 - Accelerate Feature of Automatic Speed Control Does Not Function - (1969 Ford - Speed Control Equipped)
  • Article 1532 - Engine Compartment Electrical Junction Block Assembly - (1966½-1968 W Series Trucks)
  • Article 1533 - Visual Appearance of "Dog Tracking" - (1965 Through 1969 F-100 4x2)
  • Article 1534 - Erratic or No Blower Operation - (1968-1969 Fairlane and Falcon Equipped with Integral Air Conditioner-Heater System)
  • Article 1535 - Replacement of Front Cover Oil Seal - (1968 Cortina)
