January 1968 - December 1968
Bulletin No. 104 - December 13, 1968 [PARTIAL]
(18 articles)
  • Article 1578 - Shorted Alternator Wiring - (All Cars and Light Trucks Equipped with V-8 Engines)
  • Article 1579 - Torn Front Seat Back Pivot Cover - (1968 Thunderbird Equipped with Reclining Seat)
  • Article 1580 - Insufficient Cooling, Heating and Defroster Operation - (1969 Ford)
  • Article 1581 - Insufficient In-Cab Heat - C Series - (1968 and Past Model C Series Trucks Equipped with Cummins C-160 and C-180 Diesel Engines)
  • Article 1582 - Loose Quarter Panel Outside Moulding - (1969 Ford - All So Equipped)
  • Article 1583 - Repair Procedure for Stripped or Pulled Out Attaching Studs in Plastic Front Fender and Quarter Panel Extensions - (1969 Ford and Mustang except Station Wagon Quarter Panels)
  • Article 1584 - Rear Axle Vent Lubricant Loss - (1969 Ford Vehicles with the WER, 8½" Diameter Ring Gear, Non-Removable Carrier Axle)
  • Article 1585 - Quarter Vent Window Water Leaks (SUPPLEMENT TO ARTICLE 1505, TSB NO. 99)
  • Article 1586 - Disc Brake Squeal Noise Correction - (All 1968 and 1969 Passenger Car Lines - All Units Equipped with Front Disc Brakes)
  • Article 1587 - Engine Overheating - (1968-69 Bronco, Econoline, parcel and Light Truck)
  • Article 1588 - Windnoise at Front Doors in "A" Pillar Area - (1969 Ford Sedans and Station Wagons)
  • Article 1589 - Cab Dirt Entry Thru Gearshift Lever Opening - (W Series Trucks)
  • Article 1590 - Loose or Gapping Front Door Trim Panels - (1969 Ford, All Models)
  • Article 1591 - Disc Brake Rotor - Service Replacement - (1969 Ford and Thunderbird Cards Equipped with Disc Brakes)
  • Article 1592 - Horn Button Excessive Effort - (1968 F, N, B, C 500-1000 and W Series Trucks)
  • Article 1593 - Automatic Transmission and Power Steering Fluid Specifications Superseding All Previous Articles - (All Car Lines, Light Trucks and Econolines)
  • Article 1594 - Pinched Distributor Primary Wire - (All 1969 Vehicles Built Prior to October 11, 1968 Utilizing the 351-2V CID Engine)
  • Article 1595 - New Air Cleaner Intake Tube Brace - (1966-68 "W" Series Trucks Equipped with Sleeper Cab)
