January 1968 - December 1968
Bulletin No. 099 - September 27, 1968 [PARTIAL]
(19 articles)
  • Article 1487 - 4 Speed Transmission Operating (Shifting Instructions) - (All Trucks equipped with 4 Speed transmissions)
  • Article 1488 - Air Cleaner to Air Compressor Hose "Air Maze" Air Cleaner - (C-F-T-8000 Trucks with Cummins C-160 and C-180 Engines)
  • Article 1489 - Accelerator Pedal Free Play and/or Irregular Return to Idle - (All 1967-68 F100/350 and U100 with 8 Cylinder Engine)
  • Article 1490 - Rear Leaf Spring - Bottom Leaf Askew - (1968 F-100/250, Econoline 100/200 and Bronco)
  • Article 1491 - Throttle Linkage Adjustment - (All Caterpillar Mid-Range V-8 Engine Equipped Trucks)
  • Article 1492 - New Clamp - Air Cleaner Support Brace to Exhaust Pipe - (1968 W & WT-1000-D Trucks)
  • Article 1493 - Front Engine Support Bracket - (1965-68 F-B-500-600 with 240-300 CID Engine)
  • Article 1494 - Air Compressor Oil Leaks - (1964-67 Medium, Heavy and Extra Heavy Trucks with 330, 361 and 391 CID Engines and Air Brakes)
  • Article 1495 - Windnoise - Non-Adjustable Roof Luggage Rack - (1966-67-68 Ford, Fairlane and Falcon)
  • Article 1496 - Drag link and Tie Rod End Replacement Seal - (1967-68 F, B, N-500-750 With 5000-7000 Pound Capacity Front Axles)
  • Article 1497 - Revised Method of Marking Engine Oil Level Indicators - (All Passenger and Truck Engines - Ford Motor Company Standard)
  • Article 1498 - Power Steering Pump Pulley - (All "W" Series Trucks with Caterpillar 673 and 674 Engines and Cummins NH and V-8 Series of Engines Built Prior to December 4, 1967)
  • Article 1499 - Vehicle Lean - (1968 and Past Models F-B-N- 500-750)
  • Article 1500 - New Torque Arms - (All Tandem Trucks with Hendrickson Suspensions)
  • Article 1501 - Luggage Compartment Leaks - (1969 Ford: Models 54, 57, 63, 65)
  • Article 1502 - Clicking Noise in Front Seat Back - (1968-69 Thunderbird)
  • Article 1503 - Inside Door Handle Rattle - (1969 Ford and Mustang)
  • Article 1504 - Radiator Top Tank to Supply Tank Hose Fittings - (N1000-D, NT-850-950 with 6-71 Engine, F-T-8000 with Caterpillar Mid-Range and C-6000-7000 with Dorset Engines)
  • Article 1505 - Water Leaks at the Quarter Window - (1969 Mustang - Model 63)
