Forest Service Truck Coyote Swap
miller
Re: Forest Service Truck Coyote Swap
Post by miller »
Mounted F150 gas pedal, lokar shifter and ops checked volvo electric power steering. Local shop fabricated new drive shaft.
Fordkid68
Post by Fordkid68 »
great idea on making the tank removable! should work awesomely!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
miller
Post by miller »
Passenger inner fender to firewall mount repair. I had to repair inner hood mount also.
miller
Post by miller »
Same thing for the drivers side. Bent up some metal and installed.
Fordkid68
Post by Fordkid68 »
Lookin good!
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Fuel tank installed with stainless steels straps. Parking brake cables hooked up and adjusted. I used two left hand 98 explorer cables which worked good no modifications needed. Now fuel lines, brake lines and I need to buy master cylinder/booster.
Fordkid68
Post by Fordkid68 »
Wow you are getting so close to driving it!! looks awesome!
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Cut hole in bed and made gas door. Went to junkyard and got a 90's F150 door. Put bed back on for clearance check and to make sure I cut hole in right spot. The door is centered in the bed, but tank filler offset a bit. The hinge needs a little bit of work- rust of course! Then I think I will bolt it in so can be replaced and also a bit more adjustable than welding.
So, any updates? Or are you too busy driving it!
Fordkid68
Post by Fordkid68 »
How are you?
Any updates?
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
The truck is done. 8k smiles later. This truck turned out exactly what I was looking for. Truck does great burnouts and the coyote is a great swap. I am running a mustang ecm with oem tune and runs great. Maybe Ill get an actual tune down the road but why spend more when Im really happy with it. You cant take this truck anywhere without someone wanting to buy it. Ill see if I can edit some pics and attach.
miller
Post by miller »
Truck has been done for a couple years now. The one issue I had was the in tank fuel pump spade connection came off. I had to drop tank and fix. I would recommend a fuel pump with lockable connector.
miller
Post by miller »
I do plan to to do a line lock in the future, but Im already on second set of rear tires lol
