Sealing a hole?
hotrod ford
Sealing a hole?
Post by hotrod ford »
I can get a gas tank for $10.00 at the pnp. Great price but it has a hole were they drained the fuel out of. The hole is the size of maybe a dime at the drivers lower corner. Has anyone ever plugged a tank hole before? I was thinking of a plug and jb weld. Any suggestions? Maybe I should just kepp lookin around for a tank.
1971 Sport Custom SWB: 360/C6 3.00
1965 Ford Falcon 4Dr: Inline 170 3sp
Ranchero50
Re: Sealing a hole?
Post by Ranchero50 »
I would have bought a tank without an extra hole but that's just me :)
For the repair:
1. flip the tank over so the hole is at the very top.
2. shove a water hose and rag in the filler neck.
3. turn on the water and adjust the flow so it doesn't overflow out the hole but it within an inch or so if it.
4. pick up the fallen over gas tank and hold it better while repeating 1-3
5. make a sheetmetal patch and mig weld it in place. More heat than speed so the weld flows and doesn't cause porosity.
Pretty simple and safe when you don't give the tank enough air to evaporate any gas in it.
Jamie
Whateverman
Re: Sealing a hole?
Post by Whateverman »
Ranchero50 wrote:I would have bought a tank without an extra hole but that's just me :)
For the repair:
Jamie
:lol: #4! :lol:
:2cents: a little welder's tip for if you don't want to electrocute yourself when you get your welding gloves wet after #4 occurs :wear some dishwashing gloves underneath em (i end up welding in the middle of rainstorms & i've always found the bright pink ones get the strangest looks from the other workers on site)
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
hotrod ford
Re: Sealing a hole?
What if you don't have a welder handy?
Ranchero50
Re: Sealing a hole?
Honestly, go get a tank without the extra hole and concider the $10 wasted a valuable lesson. I would not epoxy patch a fuel tank in your cab. I did epoxy and sheet metal screw the mustang fuel tank pump plate on the top of my ranchero tank back in '96 and it's held up but then again, it's not in the cab...
Jamie
hotrod ford
Re: Sealing a hole?
I will just wait then. I havn't bought the tank yet, was thinking about going this morning to get it.
Re: Sealing a hole?
yea dont even buy the tank. its junk.
randyvines
Re: Sealing a hole?
Post by randyvines »
Renchlers radiator waco texas just did mine vatted sealed and patched :thup:
hotrod ford
Re: Sealing a hole?
Bought a good one yesterday.
marvin2
Re: Sealing a hole?
Post by marvin2 »
The previous owner patched the tank in my truck. I was out of town and it "sprung a leak" while I was gone...in the garage. Needless to say, I will be purchasing a new tank, I just don't trust a patched tank anymore.
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
edglenn
Re: Sealing a hole?
Post by edglenn »
Has anyone bought an in-cab tank from LMC? They have one listed for my '72, and it looks pretty good.
Ed Glenn, New Mexico
1972 F-250 390/2V, 4 speed manual.
Ongoing restoration project
