Removing Metal dash from cab
- cancow
Is it possible to remove the dash or is welded on?
- Ranchero50
Re: Removing Metal dash from cab
It's welded at the windshield seam. You can cut them across the top and replace the face. The dash top will cover the seam.
Jamie
Jamie
Yeah, they're welded in with a bazillion spot-welds. A while back I decided to remove one from a parts truck just to see how involved it was, and I'll never do it again. Here's a shot showing the removed dash panel...you can see all the spot welds I had to drill through to remove it, which would not have been possible with the windshield in the truck.
- flyboy71
FORDification wrote:Yeah, they're welded in with a bazillion spot-welds. A while back I decided to remove one from a parts truck just to see how involved it was, and I'll never do it again. Here's a shot showing the removed dash panel...you can see all the spot welds I had to drill through to remove it, which would not have been possible with the windshield in the truck.
[ Image ]
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
