Refinished my steering wheel/column
sublimer
Post by sublimer »
Finally finished redoing my steering wheel and refinishing a steering column :woohoo:
Before: (1 of about 5 cracks I needed to fix, not to mention the engravings)
After:
Before:
After:
They didn't turn out perfect, but for spray paint and some clear coat, I can't complain :D
I may hit it up with some 2000 grit real light, but we'll see. I can't wait to install it, but I need to get bearings and all for the column first. It's from a 73, but the steering wheel and shaft are from a 68 and it's being installed in a 68. I'll post more pics in a few weeks once I get this baby installed! Wish me luck for the "unknowns."
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
Mach428
Re: Refinished my steering wheel/column
Post by Mach428 »
Looks great. You will love the finished result
1972hiboy
Post by 1972hiboy »
Thats a BIG differance, thanks for posting Id like to do something like this in the future. what did you fill the cracks with?
Rich
Dont eat yellow snow.....
sublimer
Post by sublimer »
1972hiboy wrote:Thats a BIG differance, thanks for posting Id like to do something like this in the future. what did you fill the cracks with?
Hey, thanks!
I filled the cracks with Quik Steel. It's like $5 at any autoparts store and works really well! Some tips...
1. Use a dremel and make the cracks bigger! Sounds weird, but make them about 2 times larger and deep...all the way through. This gives the Quik Steel something to hold onto.
2. Use files and sand paper...I finished with 1000 and 2000 grit paper. This was tricky because I painted it once, realized I needed to sand more and had to back up a little bit. Sand more than you think you need.
3. Take your time, I can't emphasize this enough.
1968 Ford F-100
Moveable Speakers
JWW
Post by JWW »
Thanks for the post. That looks good.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
