davbell22602 wrote:Then maybe there's a heater choke cable then? If not whats the third hole under the radio for then? The previous oner of this truck might have just stuck on this bracket for time being since i got it in pieces.
Image ]
That is the original backing plate for the correct bezels
What PO's have done to these truck will never cease to amaze any of us
If you want a deluxe set up....you'll need to find the missing control/bezel....1st(and I may not have the order right)control is the Fan control...2spd and a pull function for the amount of air coming from the fan. 2nd control is the cable that goes out to the heater control in the hose(that may be the one he used for the choke
)3rd is your Defroster....heat on the floor or out of the dash.
