Speedometer/odometer off
My speedometer reads 5 miles off (fast) and my odometer reads .01 off (fast). This happened when I replaced my transmission with a 4 spd od from an 86 f150 and a mph gauge from a 67 f600 dump truck. Thoughts?
- colnago
Re: Speedometer/odometer off
I haven't dug that far down on my truck yet, but where does the speedometer attach? If it's the driveshaft, then it's either the F600 speedo, the gearing in the rear, or the tire size. I figure that if it's less than a 10% change, it's in the noise (it's off 5MPH, but at what speed?). If you know how to compensate your speed, then it shouldn't be a problem. If the odometer is off by 10 miles every 1000 driven, then it's also not enough to worry about. But then again, since my truck's fuel gauge goes down just sitting in the driveway, I can't afford to drive more that 5K miles a year!
Just my two cents,
Joseph
Just my two cents,
Joseph
- basketcase0302
Eric,
If you remove the cable from the tranny you'll find a plastic gear on the end of the cable. I can't remember the way to calculate, (there is a way) but NPD and DC both sell the different gears to compensate for that-as well as for dealing with different tire sizes. Their different dolor-distinguished the different gear.
Once again here is "the pot calling the kettle black" as mine's been off since I built the truck a year or so ago. And I have three or four of these here.
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
The gear I'm using is from the 86 f150. I have wanted to replace all of the gauges with new ones. If I do this, shouldn't the new speedo work properly?
- 70_F100
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
- 1970 Hi-Boy
