speedometer going nuts...
- Junior Knight
just installed a new cable and now the speedometer is going nuts! speeds up ...slows down...while I'm doin the speed limit...is the speedometer bad? I have another one that works fine, but the mileage will be off..how can I change it to the right mileage? Thanks! 67 ford f100...
1967 Ford F-100...goin back *STOCK*..just sayin
Re: speedometer going nuts...
Sounds like the cable is binding or some gears are missing teeth.
Common Sense is an Uncommon Virtue
- PhantomoftheBumpside
Definitely sounds like binding. Either it's got a less than minimum radius bend somewhere that you need to relax by re-routing, or, you kinked it somewhere (usually at the end when hooking up the dash), or the cable is dry and grabby and is asking for a little lube (grease)...
-- ROB --
The collective money pit details...
-On The Road-
1990 * 1FTEE14YZLHA83xxx ..- 138 E142 __ E 18 __ 3P
-Projects-
-Spares-
-Recently Departed-
1997 - 4M2DU55P9VUJ46xxx...- 112 4 22 _ _ 8 D4 U 1F
1997 - Dodge Caravan
1987 - Toyota Tercel Wagon FWD
1978 - Winnebago Brave (Dodge D800FC)
1970 - F10YRJ80xxx ..............- 131 3 F100 D _4 G 02
1968 - F25YRC99xxx .............- 131 E F253 B 81 G C8
1968 - F25YRD69xxx .............- 131 C F254 E 81 A 24
-On The Road-
-Projects-
-Spares-
-Recently Departed-
- Junior Knight
ok..thanks, I'll lube it ..don't think its binding but will ck again...
if the needles freakin out and jumping all over its most likely the cable binding,if its not jumping around,check out the speedo gear the teeth can get chewed off if the cable binds up for too long
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
Another one, make sure the exhaust isn't cooking it. I lost one to that.
- michael69
Be sure to use graphite grease.The others will attract dirt and become thick and gummy and case more problems.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
mrollings53 wrote:Another one, make sure the exhaust isn't cooking it. I lost one to that.
- cowbay
X3Whateverman wrote:mrollings53 wrote:Another one, make sure the exhaust isn't cooking it. I lost one to that.me too
"If it can't be fixed with a hammer, then it is an electrical problem"
69 Ford F100 Ranger 390 3spd with overdrive
63 Chevy Impala 327 with 4spd. In the family since brand new. Over 280,00 miles
- timmytim
Speedomters seems to be a problem issue with our trucks. I cleaned and greased mine but it still jumped around. So I bought a new one from lmc. A few months later speedometer back to jumping around. I guess there is something good about electronics after all
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
cowbay wrote:X3Whateverman wrote:mrollings53 wrote:Another one, make sure the exhaust isn't cooking it. I lost one to that.me too
- austin
i had the same problem turned out to be the speedometer it would squeal really loud too
