69 F-250 interior parts wishlist
nchorsepower
Post by nchorsepower »
I need the metal trim piece that goes over the steering column against the instrument pannel, a perfect 4 speed shift knob, and one of the little chrome, round, hole block off pieces that would be on a 67 below the instrument cluster. I think the owner removed the flasher switch when they installed a trailer brake system. Steering column harness and turn signal switch. dome light lense. Crew cab headliner center trim piece. Crew cab rear door floor mat hold down trim pieces. Trying to get my truck back to original.
elgemcdlf
Re: 69 F-250 interior parts wishlist
Post by elgemcdlf »
http://classicfordtrucks.shutterfly.com/ Call Riff & tell him Steve from Indianapolis sent you.
flyboy2610
Post by flyboy2610 »
Do you mean the shiny red metal piece shown here that goes across the top of the steering column?
I have one, but it'll need cleaned up and painted. It's in good shape, no rust. $15 gets it shipped to your door.
Let me know.
Red Green
you'd better be right.
Calfdemon
Post by Calfdemon »
As mentioned in your other thread, I might be able to hook you up with my headliner center trim as I need to see if my other idea will work. Ill let you know when I can... Maybe I can get on that soon to mock it up and see if it will work.
As for the floor trim inside the rear doors that goes over the mats, like most of the things with the crew cabs, Ford just used front pieces and cut them to fit. So all you need to do is get a pair of regular truck floor trim and then cut them. Here is my stock front and rear together, with a close up of where Ford cut the pieces for the back:
As for the trim pieces, I am going to have an extra pair of the floor trim which is fair condition and just needs to be cleaned up. I can even cut them at the proper spot for you for use on the back doors which will make them easier to ship. I can hook you up with those along with the center headliner trim once I am certain I am not using it.
-Rich
Current toys -
Former toys -
nchorsepower
I joined Riff's site. It would be awesome to find all the original parts for one of those dealer installed PTO winches and front bumpers.
