Painting instrument bezel
- benden
Does anyone have any pictures ofa painted instrument bezel? I have a new lens and have cleaned the guages up. I have thought about doing satin black or I suppose I could use argent silver. Just trying to dress it up. Thanks.
Bryan
50 chev coupe
56 chev 1/2ton stepside
1969 F100 Custom Cab
1970 F250 Ranger XLT Camper Special
95 F150
05 F350
50 chev coupe
95 F150
05 F350
- michael69
Re: Painting instrument bezel
I used argent silver and gloss black. Was going to paint the FORD letters black,but I have a f600 cluster I am going to swap in so I never did.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
- benden
Michael, looks great. it looks like it would take some effort to mask off the black areas. You did a great job.
Bryan
50 chev coupe
95 F150
05 F350
50 chev coupe
95 F150
05 F350
- michael69
Yea I painted all the black first and let dry for a day, then taped it up and sprayed the silver. It wasn't that bad. Just covered all the black and used a razor blade to trim of excess tape,took about 30 minutes.
Michael69
- abe
Did you remove the instrument panel to paint it or do it in place?michael69 wrote:Yea I painted all the black first and let dry for a day, then taped it up and sprayed the silver. It wasn't that bad. Just covered all the black and used a razor blade to trim of excess tape,took about 30 minutes.
1970 F-350 flatbed dump, purchased 9/20/12
1954 F-100 bought from Grandpa in 1977 for $200
- michael69
Removed it and took it apart,so I had just the bare plastic bezel to work with.
Michael69
- benden
Any tips on primer or taping. Looks great..
Bryan
50 chev coupe
95 F150
05 F350
50 chev coupe
95 F150
05 F350
- michael69
I didn't use any primer. I just scuffed it up real good with scotch brite.Wiped down with lacquer thinner,sprayed the black.Let it dry for a day and taped the black.Just used new razor blades to trim the excess tape.Then wiped down again with thinner what was not taped and sprayed the silver.
Michael69
- benden
Boom!! Done. Thanks.
Bryan
50 chev coupe
95 F150
05 F350
50 chev coupe
95 F150
05 F350
- michael69
Oh yea, pull tape off while the silver is still wet. That way it won't leave a raised edge that will peel paint off. If you what till it's dry it may peel paint off on the edges.
Michael69
- Stickbow
Probably should search first, but....where did you find new lenses/"glass" for the panel? I spent an hour plus polishing mine last night to get rid of 44 years of yellowing and pitting, but it still isn't what I want.
I did what michael69 suggested you do to clean and mask (great minds and all). I used satin black - not sure if he did or not.
Stickbow
'69 F100 360cid Custom Cab LWB in Lunar green..or what was Lunar Green 43 years ago.
Here is a picture of mine in all black.
You can get the lens from LMC for $20. Probably Macs, NPD and Dennis Carpenter for about the same.
- michael69
Michael69
- Stickbow
Thanks jrreed1634. I actually asked before looking, since I messed with polishing 'til 1am last night, then posted that when I first jumped on Fordification looking for something else.
Will post a pic when I get it done - always forget to do "before" pictures.
Stickbow
- stephen44
nice jobs ! - what aftermarket gauges do you all use in the f600 ones ?
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
