Painting instrument bezel
Re: Painting instrument bezel
- michael69
I have all the original gauges that work and in great shape that I am going to use. I bought an aftermarket tach that matches the other gauges that will be used. I will post a picture of it when it is back together and in truck.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Michael, Bezel looks great! I have one question though did you paint the instrument part also or buy it in white? That also look good. Thanks SHU
- michael69
The gauges have an overlay on them.You can get them off ebay or from their website...whitegauges.net
Here you go they are on sale now http://www.whitegauges.net/products/196 ... auges.html
Michael69
- la1031
I posted this here a long time ago but here is my F600.
These are 3 3/8 speedo and tach and 2 1/8 other guages. None of them fit the holes as the originals mount behind the panel. I fit these surface mount and it came out pretty good, but you will be one with a die grinder opening all those holes. Check my photobucket for pics behind and all to see what I did.
http://s446.beta.photobucket.com/user/1968F100/library/
1968 F100 Shortbed
302/306 roller, C6 w/shift kit
3.70POSI w/trackbars
Hydro-Boost
Hoping for 13's and looking good doing it !!
Makita Industrial Power Tools
Tools for the long run.
1968 F100 Shortbed
Hydro-Boost
- stephen44
I only see 3 generic pictures of your truck when i go to photobucket and search for you - none of the gauges ? - is that correct ?la1031 wrote:I posted this here a long time ago but here is my F600.
[ Image ]
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
Thanks Michael69 I'll check them out.
- la1031
Yeah my photobucket link was messed up. Try now.
1968 F100 Shortbed
Hydro-Boost
1968 F100 Shortbed
Hydro-Boost
Old picture before i pulled the interior apart to redo
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
- feefie
Where did you find white background speedo and gauges with black letters?? Interesting I have never noticed one from the factory like yours. Always thought they were all black with white letters.michael69 wrote:I used argent silver and gloss black. Was going to paint the FORD letters black,but I have a f600 cluster I am going to swap in so I never did.
Stu
Doing what is right isn't always easy....doing what is easy isn't always right.
1968 Mercury M-250 clone
1976 F-250 Highboy
1976 F-250 Highboy
- feefie
I should have read the 2nd page.....I will look for the over lay on ebay.
1976 F-250 Highboy
1976 F-250 Highboy
- michael69
You can get them here just as cheapfeefie wrote:I should have read the 2nd page.....I will look for the over lay on ebay.
Michael69
- feefie
michael69 wrote:You can get them here just as cheapfeefie wrote:I should have read the 2nd page.....I will look for the over lay on ebay.
Very Cool! I need to get out more.......
Stu
1976 F-250 Highboy
1976 F-250 Highboy
What type of paint/gloss did you use for this it looks good I'm wanting to try this myselfmichael69 wrote:I didn't use any primer. I just scuffed it up real good with scotch brite.Wiped down with lacquer thinner,sprayed the black.Let it dry for a day and taped the black.Just used new razor blades to trim the excess tape.Then wiped down again with thinner what was not taped and sprayed the silver.
Here is what my son and I did for his truck. Went with white to match the two tone factory paint job. Like mention before, tapeing off is the hard part.
